did some testing with a castle/ Neu 1515 2200kv & a hydra 240 . Running M 445 / M 447 / M645 & getting speeds ranging from 57 - 65 mph with no heat issues & a peek of 204 amps . i changed the water pick up to behind the prop & as u can see from the graph the temps were all low . This test was to sort out the cooling issues with stock water pick up. Cause Heat = loss of power & my speedy & motor were running way to HOT with the stock set up. Well with my UL1 anyway !!! The speed thing is just an added bonus ..... with the stock water pick up my Temps were double of what you see on the graph....
Temp 1 = Caps
Temp 2 = Esc
temp 3 = Motor
