As you probably have seen in my build thread, I built a Rio Ep and have a couple questions.
As described in my thread I also built with my friend an NQD Arrow wind. Now, the motor, prop, battery and ESC are all the same but his will go faster than mine.
1) Why would this be? I thought about how much of the boat is in the water but mine is lighter than his!
2) How could I push a little more speed out of mine? I'm using the stock 42mm prop as I tried other sizes both larger and smaller and couldn't push more speed out of it.
3) I have alot of problems with the boat torquing to the right an risking flipping if I go too fast, is there a way to eliminate this?
Thanks for the help!
