Results 1 to 6 of 6
Thread: Couple questions regarding SuperVee Brushless Motor/ESC
    Sep 2009
    3
    Default Couple questions regarding SuperVee Brushless Motor/ESC
    Hi,
    Can a SuperVee Brushless motor be run in both directions? For counter-rotating purposes?
    What is the arrangement for the wiring from the ESC to the Motor? I purchased a motor and esc, but the leads were clipped off.
    Thanks!!
    Jan 2008
    Mo
    2,716
    Yes it can. Just hook the ESC to the motor and then check direction of how it runs and then if you want to change it just swap any two wires and it will run opposite direction.
    Sep 2009
    3
    Cool, is there any special way to connect the three wires from the motor to the esc?
    1,969
    Quote Originally Posted by themissinglink View Post
    No, it does not matter. If the motor is running the wrong direction, just swap 2 of the 3 wires,
    -Chief
    NJ
    36
    Why are their 3 wires? I would expect just two for a DC motor.
    Sep 2009
    3
    Seems like Brushless is similar to an AC motor.
