Results 1 to 8 of 8
Thread: some testing of vs1 and MM for sport running
    Sep 2008
    OZ
    2,865
    Default some testing of vs1 and MM for sport running
    VIDEOS ARE FROM PHONE (no zoom) and there loaded directly from phone to you tube so phone compresses file
    doing some testing running sport setup to get longer run time as i dont race.
    first up is my vs1 running a scorpion 3026 1900 kv on 4s 30c 5000 zippys
    m642 prop, esc is mystery 100a with cooling plate, timing set at 15 deg timing.after this run motor and esc at caps were under 40c (100f)
    should be good for 3-4 minutes of fun
    Sep 2008
    OZ
    2,865
    this is my mean machine, same deal setting up for more run time.
    set up is feigao 8xl on 4s 30c 5000 turnigy, mgm 12024 esc, x637
    temps after run were 43c (109) motor at end bearing,40c (103f) esc caps)
    should also be good for 3-4 minutes
    during the start of the run you see it stop in the water for a acouple of seconds as the steering was not rite,thought it was my exponential set wrong but when
    i got it back after the run the rudder had hit some thing at the start and was angled back about 15 deg, and yes i did hit the tree branch
    Jul 2009
    QL
    395
    Bloody Tree's!!
    Sep 2008
    OZ
    2,865
    yea makes it hard to see for us, think acouple may fall over soon
    least we will be able to see our boats when they turn
    1,320
    "with cooling plate set at 15 deg "
    is it any faster with the colling plate set at 20 degrees? J.K
    Sep 2008
    OZ
    2,865
    you got me there
    i just changed it,it was suppose to read "timing set at 15 deg"
    Jun 2007
    5,190
    The pond is a beauty. Was that Paddy's new phone?
    Interesting run on the X637 and temperatures.
    Douggie
    Sep 2008
    OZ
    2,865
    no its of my phone,paddy lives about 1600 klm (1000 miles) from my place
