Results 1 to 29 of 29
Thread: Resurrecting a Superior
    4,204
    Default Resurrecting a Superior
    Well after the wicked crash I looked it over and decided attempt to re-build. So far I sanded it down to the fiberglass, laid new fiberglass and then and started to re-sand. After I laid the fiberglass I did a leak test in the bath tub and all went well. I started to resand and get a smooth finish today and found a few area's that need to be addressed before I continue. After I am done sanding (hopefully tonight) & adding some additional fiberglass to some week spots I will put all the hardware back together and run it like that. If all goes well and it runs good I will then re-paint. I ordered another esc for my set up. I keep debating on whether I want to attempt the 7xl set up again or go back to stock power. I don't want to give up on dialing this boat in with the 7xl set-up, but their is a lot of work to do with it.
    - Diesel's Youtube
    - Diesel's Fleet
    Oct 2008
    9,488
    right on man, right with ya on this!
    6,453
    Good job bro! Are you going to fill the sponsons with expandable foam?
    4,204
    I'm not sure. If I do that would it limit my ability to splay the batteries through the sponsons?
    Ammo 2600 is too high kv for 4s. My Ul-1 coulsn't handle the power of the 8xl. Lots of chine walking! The ammo 2300 may be an option. IMO the stock motor is plenty for this boat though. Maybe upgrade to a 120 amp esc and try propping up a tad.
    I need more weight. The boat still would not keep the front down even with 2 4s lipo's in normal battery config ran in parallel. The 7xl may just be too much motor. I may step down to a ammo 2300 with a sv esc? Any thoughts to how that would work?
    Rum you called the 2300 a long time ago as an option. You may right with that.
    - Diesel's Youtube
    - Diesel's Fleet
    Dec 2009
    54
    Jesus Christ ... what wicked crash? My hat is off to you wanting and trying to fix the body ... I'd probably just buy a new hull. Let us know how it comes out.
    4,204
    Quote Originally Posted by Colby View Post
    Hit a possible turtle at 51mph on the gps. It was actually a pretty clean break. Thought about scrapping i, but had a crap load of fiberglass and resin laying in the shop so said what the hell I'll give it a try. Only took about 5hrs. I just finished tending to the gaps I found, so I should be done tomorrow. I'm just waiting for it to cure right now.
    - Diesel's Youtube
    - Diesel's Fleet
    Dec 2009
    54
    Just read down to your other post regarding the crash ... holy sh**. I'm looking at upgrading my UL-1 as well but now may give it a second thought ... high 40's may be fast enough.
    4,204
    It was blast on the 7xl (video is in my signature if you haven't seen it), sadly I just didn't have enough time to dial it in. Crash before I could try somethings, i.e straight turn fin to loose some lift or airdam for a few. I think like rum said a 2300 ammo may just be that happy spot.
    - Diesel's Youtube
    - Diesel's Fleet
    4,204
    I just finished repairing the the nose cone. Luckly for more when it broke off the the cone floated and the the broken piece was still taped to the hull. I cut some fiberglass up and mixed it with the resin. I use tape to hold the pieces together while it cured, seems ok now and strong.
    - Diesel's Youtube
    - Diesel's Fleet
    1,969
    I need more weight. .....
    I would think by adding foam in the sponsons would help with weight, and you could still dig out holes for the lipos-- you might even get a more secure fit for the batterys that way.
    I love that boat of yours, glad you decided to repair it!
    -Chief
    May 2007
    co
    1,973
    Colby dont worry about breaking the hull, fiberglass is easy to repair! Plus there are a few boat modelers down here in Pueblo that could easily fix it! Diesels hull just split at the seam, pretty common actually, oh and don't hit a bouy with these hulls either, the damage looks about the same.
    4,204
    -Chief
    I'm kinda of scared of the expanding foam. I have a heavy hand I don't want to spray to much and spilt the hull again. I'm still open to the idea though seeing people way more experienced than me are suggesting to do it. I have yet to re-work the turn-fin area so I would want to do that before I add foam though.
    - Diesel's Youtube
    - Diesel's Fleet
    6,453
    use small shots, let it cure for an hour and add more as needed. Since your tub is cut out for the lipos, the foam will always have somewhere to escape so it won't blow up the hull.
    4,204
    Is their a specific brand or type I should purchase? I imagine Home Depot or Lowes would carry it.
    - Diesel's Youtube
    - Diesel's Fleet
    Jul 2009
    MA
    251
    Keep the project going Diesel....You and I have been on the parrallel build path with the 7XL in the UL-1....I've been watching your build and test very carefully....It's not too much motor...Mine was hopping and dancing so badly that I thought I had it over-powered too, but moving my strut down and messing with the angle has made the UL1 pinned to the water and very stable.....slowed it down to 47mph, but at least I know that it will stick, now I only have to tweek it back up and find the sweet spot...I'm running the CC240 in one and Etti 150 w/caps bank in other, and I am pleasantly surprised with the Etti (cost and performance)....BTW, both of mine were total wrecks, fixing them is half the fun....Norm
    Jul 2009
    MA
    251
    Also, I used the non-expanding foam from Home Depot...I drilled another drain hole in the transom on the starboard side to match the stock hole on the port side...I made an extension tube from some old teflon liner and fed it down all the way to the front of the sponson, injected foam while drawing the tube back out, did the other side and let her sit overnight...the next morning, there was solid foam oozing out of the holes, so I shaved them down and sanded, and they are solid! I have so much fiberglass on the sponsons from past crashes, that I think it added the very weight to the front that I was also looking for...Don't give up, keep her alive, she will serve you well!!
    6,453
    I used greatstuff foam. I've gotta ask, ncornacchi, what's the point in all the expensive hop ups if it is no faster than stock. With a 7xl (too much motor) you had to drop your strut so deep that it is probably making it run super wet on the sponsons and lose tons of speed due to drag.
    4,204
    Is this the stuff and same color can you use? Seems they have a lot of different types under the greatstuff name. Thanks
    - Diesel's Youtube
    - Diesel's Fleet
    Jul 2009
    MA
    251
    Rumdog, I don't think it's too much motor, it's just not dialed in right yet...I got everything I could out of the stock setup, and just wanted to step it up a notch and have some fun
    4,204
    Well she's alive. Got a chance to run it today. Since today was just a very easy going test I dropped the power down and ran it with SV power, stock collet and flex cable and a CF42 prop, strut was at 1" and neutral. I left the aft fins off and also forgot to put the drain plug in but shockingly she only had a little and I mean a little bit of water inside. I hit the trigger she submarined I let her bounch back and floored the trigger again and she shot out of the water and ran wonderfully. Since the SV power was installed she was glued to the water and ran perfect. I couldn't have asked for a better first run after repair. I will sand just a little bit more and then I will install the motor (going to try the 7xl again) and waiting for my esc from HC and also need to order another tactic rx. After I install the motor and esc and see how shes runs I will see if I need to sand some more than I will paint later down the road.
    Last edited by Diesel6401; 04-04-2010 at 11:30 PM. Reason: The second pic was after I started to disconnect everything and figured I'd take a pic. That's why its half a$$ connected.
    - Diesel's Youtube
    - Diesel's Fleet
    Dec 2009
    54
    Great Job ... you got more patience than I do. Glad to hear you are going to put the 7xl back her.
    Jan 2009
    AL
    301
    Cool...another UL-1 back in the water after a wreck....good job dude!
    4,204
    Quote Originally Posted by Capt. Crash View Post
    Thanx a lot.
    - Diesel's Youtube
    - Diesel's Fleet
    Mar 2010
    mn
    54
    nice job diesel, that was fast. glad to see that your boat is back. can't wait to see when it's done.
    4,204
    Quote Originally Posted by speedfreak View Post
    Thanx man, fixing is half the fun (sometimes lol)
    - Diesel's Youtube
    - Diesel's Fleet
    Sep 2009
    HI
    1,679
    Hows your boat going? You repaint it yet or are you gonna go back to the big power setup and dial her in first?
    4,204
    Quote Originally Posted by BakedMopar View Post
    right now im waiting for my esc to arrive from HC. Once I get that ill be back in business. I'll repaint after i dial it in. Yea i'm going to try th 7xl again, if progress doesnt go well I'll try a ammo 2300
    - Diesel's Youtube
    - Diesel's Fleet
    4,204
    Well got my new esc in from HC today. Going with the aquastar 120amp again. I am going to cut off the old shrink wrap and spray it with some liquid electrical tape to make it a little more water resistent i am also going to add the cooling plate I took from the fried esc to this new one to try and get better cooling, after that I will re-wrap it with some F4 tape I have laying around the shop. Hopefully I will have it back in the water monday or tuesday.
    - Diesel's Youtube
    - Diesel's Fleet
    May 2010
    MO
    3,278
    Default Capps.
    You wouldnt happen to know anything about adding extra capps would you?I need advise on some extra capps I have.Thanks.
