Email me from the ose contacts page and I can get it to you asap.
Steven Vaccaro
Guys look on the bright side. It may not have worked yet, but least they haven't burst into flames on plugin *cough castle*
man aint it the truth...theres nothing worse than buying one of the worlds leading esc's (castle) and have it blow up in your face on the first try
I have high hopes for these 240hv esc's...they are awesome looking and have water cooling and are a very nice size considering how powerfull they are
my two will get the acid test running each one on 12s2p
I still get nothin. Made the polarities in the connectors correct. Followed each step. Aaaaand Connection failure.
I shoved my disk into my laptop and it took the program just fine bustit..i did have to update drivers for my com ports but i got through it and was able to program it....as far as power up i followed your video steven but after i release the trigger on my dx2 radio it continues to beep and will not leave the programming mode...any ideas steven?..the fish has not turned my neu 1527 yet but i am close...
"FE" STANDS FOR FRUSTRATING EXPLOSIONS
I had the same problem at first. Each step has to be done exactly.
What is the uart to com port number?
Does the screen update when you plug in the rx wire to the usb?
Is the USB link showing a red light?
Check and make sure the com port is not being used by something else. The usb port powers the esc, so make sure you don't have batteries plugged into the esc. Lastly post a picture of the layout so we can see if there is anything else you maybe overlooking.
Steven Vaccaro
Steven Vaccaro
I JUST GOT IT TO TURN...I HAD MY BRAKE PROGRAMMED FOR OFF BUT YET I SET MY RADIO FOR FULL BRAKE AND IT WILL THROTTLE UP...TOO STRANGE..I AM NOT GOING TO TOUCH ANYTHING! I CAN FINALLY TRY ANOTHER BOAT YAY
comm4. Red light is on. Updates when I plug in the usb adapter, and when I plug the rx wire harness into the usb adapter. Turn on the switch, select comm port 4 and open, then hit connect. no connection still.
Will do Steven, Thanks for all the help man. I feel like I'm being a pain in your arse.
Do you have to do this proceedure every time you power up?..it seems that way or else it keeps on beeping into different tones
steve
did you get my message about getting the swordfish software?
actually you do not have to wait until the end of those beeps - just hold throttle until it starts beeping :-)
At the end you'll hear the number of cells detected
http://www.offshoreelectrics.com/dow...40hvManual.pdf
se page 3 for more details
One important info: throttle range sometimes needs to be calibrated after changing ESC's settings.
By the way - the fast startup mode is awesome especially for competition.
Regards
Thanks for the info. I fixed your link so it points to the actual products instructions.
Steven Vaccaro
Software and manuals can now be found here.
http://www.offshoreelectrics.com/downloads/hifei/
Steven Vaccaro
ok got the software installed and when I have device manager open and see the uart bridge controller it says i'm on com6
and the software only has com1 com2 com3 com4 ...there is no com6 in the software
any fix?
try com3 :-)
I had almost the same problem.... so I tested each port.
Procedure is simple: choose other ports and hit "open" button (and wait for green light)
In my case only com3 was ok (even if it's not shown in device manager)
hope it helps
Regards
Mieciu
ok I tried that mie but it wouldnt work for me......BUT I found the fix...just right click on the uart bridge controller in device manager and choose properties then the port settings tab then advanced and it allows you to change the port com settings...I only had com2 the was available and it worked
Hey steve, bustitups son-in-law here. If running 44+ volts should i set the voltage to 36volts when i program it or leave it on auto? And is there a way to program the esc to run only 90% or can it only be only be done with my controler .
Are you running a 12s lipo pack?
Steven Vaccaro
yes he is running two turnigy 6s packs on each motor and they are in series to each motor
hey steve, its eric bustitups son-in-law. i bought two of the big swordfish. one i cant get to beep or make any noise. need to send it back. do i need an rma #? other one seems to be working fine. will also need to replace the screw in water fittings. i read where they said they were leaking and and broke some trying to tighten them. boy there fragile. let me know what i need to do?
For returns its best to email me. You can from the contacts page
http://www.offshoreelectrics.com/contact.php
Steven Vaccaro
