Im running a 11xl on 6s with a ETTI 150a esc...
What kind of charger should I get?
I was thinking the IMAX B6... and the 12v 5a Power Supply?
After all is said and done, more is said than done.
I would recommend you get a charger capable of at least 8S and 10A charge rate. The 5A power supply isn't going to carry it. It doesn't cost that much more to move up in chargers. You'll be upgrading in the future if you don't do it at the outset.
Mini Cat Racing USA
www.minicatracingusa.com
A 5 amp power supply is not sufficient as when a load is placed on them, most tend to be over rated. If you budget allows, Rivergate (Bulldog Power Supplies) are excellent. I have a 45 amp version and run 7 chargers off of it.
Grand River Marine Modellers
yea them crap power supplies they sell are worthless unless using it for a laptop or similar
there lucky to hold 3 amps
The IMAX B8 is powerful and better than IMAX B6, so prefer 150 Watts IMAX B8, I' ve got this charger, it' s fantastic
I would suggest a 20 amp power supply as a minimum. Imax, I am not familiar with and can not make a comment. I use FMA chargers and love them...they are idiot proof and I need that feature!!
Douggie
douggie got any links?
and i called my local hobby store they said its better to buy a 3s lipo charger than a 6s charger and charge 2, 3s lipos in series...
duh, hate to say it but your LHS isn't the sharpest knife in the drawer! You can't charge two 3S lipos in series with a 3S charger!!!
Mini Cat Racing USA
This is the power supply I use. I can hook up a BUNCH of chargers at the same time.
http://cgi.ebay.com/ebaymotors/Iota-...item2c53be5f26
I also connect a distribution panel to the power supply:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLWE5
The ebay seller has smaller power supplies but I wouldn't get anything less than 24 amps.
Mini Cat Racing USA
hahah i meant to say that they said charge ONE battery at a time on a 3s charger
I really like this charger, is it ok?
http://www.hobbypartz.com/thac6smbachw.html
awesome thanks i will try to order it soon..
This charger is a SkyRC IMAX B6 AC
http://www.skyrc.com/indexhome.htm#/...t/Charger/b6a/
you guys were sayin at least 20amps???
No, at least 20A power supply, not charger. I've never seen a charger that puts out 20A!
Mini Cat Racing USA
I was saying 20 amps, as at times I have 2 or 3 chargers hooked up to the power supply. The cost difference between 10 and 20 amps is marginal.
http://www.fmadirect.com/
Douggie
oh thanks guys..
sooner or later (maybe a year or two)
ill be a FE Addict!
ordered the charger! :)
now i have to order two 3s lipos!
The power supply on Ebay is a MUCH better deal. It is a commercial unit. Super heavy duty. NOT chinese. It is 55A for $102.50 + $15 shipping. The retail on it is close to $200!
the one on FMA is only 28A and it is $130.
Mini Cat Racing USA
That's cool
