What would be a good pipe for this new Rio 51z ?
and how much will that help?
thanks
Darin E. Jordan - Renton, WA
I am very impressed with the "solidness" of this hull, and it's also layed out very nicely. There are many features that are obviously done with ease of maintenance in mind (oiler, etc.)...
Order this: http://www.gizmomotors.com/index.php...mart&Itemid=56
It's a bolt on top-end kit that is VERY easy to install. You can use your stock carb with no worries.
You could throw in some zero-drag seals, but that requires that you pull the flywheel, and aren't really necessary for most running.
You'll be very impressed with this top-end kit and a pipe. Performance is quite amazing for the $$$
Maybe you could talk Brian (Buaas) into snapping some pics of his. He did some tweaks to the motor mounting to enable him to install the pipe down inside the hull without having to cut the hatch.
