Results 1 to 5 of 5
Thread: Connector Tip (Castle 5.5)
    Nov 2008
    WI
    662
    Default Connector Tip (Castle 5.5)
    Racers, For what its worth!
    I have been updating my race boats to Castle 5.5mm bullets.
    I know behind the times… I really do not race FE boats all that much and to date never toasted a deans but its time to update my fleet.
    What I have found is the ID of the female Castle connector to be +/- .009" (WHEW!)
    To help identify what female connectors you want to use before you solder: Purchase a .215" gauge pin. If the pin fits, use the connector. if not, pass on that one and test another.
    If you feel you need more precision then that buy both a .215” gauge pin and a .217” gauge pin. The smaller one must fit and the larger one not.
    What you will find is a fit that does not become compromised cycle after cycle.
    Grimracer
    Va
    4,670
    Great advice - do you have a link for the go/no go gauge?
    IMPBA 20481S D-12
    Jun 2008
    GA
    2,318
    Mcmaster Carr sells them $3.09 each. Search under part# 2275
    www.mcmaster.com
    Va
    4,670
    Thanks for the info detox.
    IMPBA 20481S D-12
    Jan 2008
    Mo
    2,716
    I spread the male legs out a bit to get them to fit really tight. If you leave them they are fine but if you take them on and off then make sure they have a tight fit.
    China stuff is what it is about--- low QC.
