Results 1 to 8 of 8
Thread: busted shaft
    Oct 2008
    ky
    240
    Default busted shaft
    has any one had this happen???? the solid part of the shaft were it meets the flex cable spins??? you can hold the flex cable and twist the solid part of the shaft????
    Oct 2009
    NC
    4,204
    Quote Originally Posted by jlr3rd1 View Post
    I ordered the upgraded flexshaft from kintecracing. Way better made than the stock. Not sure if this helps, but it works very VERY well. Good luck.
    - Diesel's Youtube
    - Diesel's Fleet
    Oct 2008
    ky
    240
    yes it does thanks :) i will check it out thanks
    Jan 2008
    Mo
    2,716
    Silver brazed is the way to go. Most use loctite and silver solder....as I did as well but now I sell these. Not fun to make but they do not fail.
    I have them on my site. You might send it to me and if it is clean enough I will braze it for you.
    Oct 2008
    ky
    240
    wow thanks :)
    ma
    8,693
    I carry a pretty nice cable also.
    http://www.offshoreelectrics.com/pro...od=ose-svcable
    Steven Vaccaro
    Jul 2007
    WA
    404
    that very same thing happened to a cable in one of the SV's at our club race yesterday. The replacement Steve has here is great...get 2 and you should be set for life.
    Oct 2008
    CO
    9,488
    Quote Originally Posted by Steven Vaccaro View Post
    I put one in my MM this weekend and that is a very nice cable!
    now I need one for my SV and UL-1
