Results 1 to 3 of 3
Thread: will this work
    Aug 2009
    fl
    147
    Default will this work
    will this go well in the sv with a 120a esc?:
    KD36-74-09XL 1900kv Brushless Inrunner
    The KD36 inrunners are equivilent to 540 size motors.
    Front mount holes are 25mm apart.
    Dimensions: 36×74mm
    Shaft size: 5mm
    Weight: 370g
    Spec.
    Kv: 1900rpm/V
    Idle Current: 2.6A
    Resistance: .0091
    Max Amp: 75A
    Oct 2008
    9,488
    yes that should be a power house, not sure about the esc..
    you could put it to it's limit
    Aug 2009
    fl
    147
    thanks for the info
