Been trying to create something new that can cool the internal parts of the motor such as the rotor, windings, etc while running....even after running/racing this can keep running to pull heat out of the motor and cool it down very quickly.
It is a 5V fan that is vac formed around the motor. Granted, you do have to have holes in the front and rear of the motor housings but that is easy to do on any motor or if you change the bearing. Many top motors already have holes.
I hook it up to a very small 300 mah 7.4 lipo from my plane and she runs forever. Small brushless fan in it. It is a 40mm fan but considering a 50mm.
It is not perfected yet a bit of sizing to do but I think it has great potential. All that needs doing is sticking on and cut your motor exit wires and then seal around the wires with a little silicone.
Maybe a person could even hook the ESC behind it and blow on it as well.
Tell me what you think.
