New to boating. Could anyone tell what type of clear is used on the wood of the VS1. I purchased a new one and would like to re-clear the wood to make sure that it is sealed. I am not sure what to use. Any information would be great. Thanks
I believe it's finishing epoxy. That's what I used to blueprint the sponson bottoms.
Namba District 16
I don't think so. I just stripped mine and used off the shelf paint stripper. Came off with scotch pads once it sat for about a 1/2 hour.
What ever it was covered with it was absolute garbage. I am refinishing it with Wes Systems as a base and then rattle can it. The problem is at the factory they really don't seal it very well. They miss a lot of edges, nooks and crannies. This leads to water soaking in and pieces coming unglued. They also experience mold build up in the wood.
Good running boat just remember it's made in China buy people making a couple of bucks a day. Do you really think they care how well they finish it?
Good luck with the Project.
Oh yeah. UL1 motor and start with an x440/3 cupped up. Once you start playing with props it's good for about 50mph. 4s1p 5000 will do it too.
HT
Thanks for the information.... I am planning on re-sealing it and then spraying it with an automotive clear that Grim Racer said he uses. Thanks again.
Billy Graham
I am going to check all the seams and make sure they are fillled with epoxy like the instructions say. Then if some need filling I am going to fill them. After this I am going to scuff the clear that is on it and re-clear it. This is to prevent any water from getting into the wood or boat. I was asking to see what other boaters did to their VS1 boats. This is my plans.
I found a couple of areas I filled with epoxy with micro baloons along the center section
Billy Graham
It would depend on what type of paint stripper it is.
Aircraft type is very strong and will remove paints you wouldnt thin can be removed.
T.C.
It's not epoxy. Very cheap lacquer type coating but easily sands off. Listen to Howard.
The only thing bad about the hull is the coating. A bit of sanding and west systems or sim will take care of the seams that may not have been sealed properly.
When setup properly it is a very good hull. I have ran mine on spec power and it get's into the low 50's with good handling characteristics. No one I know of sells a wooden hull assembled for that kind of $.
Sounds like it will be worth sanding the coating off and resealing and maybe throwing a paint job on mine
Jim
Billy Graham
Spray the outside with two coats of this stuff. It will seal the original finish just fine.Link
You may still want to re-seal the inside with finishing resin/epoxy.
I have PPG auto clear I could just use that
Jim
Billy Graham
If LuckyDuc's clear coat ia anything the PPG stuff I have I haven't found anything that it won't go over.
Mine is PPG Shopline JC661 Acrylic Urethane clearcoat.
Jim
Billy Graham
I like the way it runs just not the build quality!
what bums me out is the guy my dad got it from told him he resealed the hull and all the seams ( you can see some areas that were filled) so we did not bother to seal it,
oh well it cost $100 with a complete O.S 21XM set up and Hitec 645mg servo!
Don't tell Mike ANYTHING!!!! He's a core member of MI now...ya know the enemy!!!! :)
Mike, I would not go so far as to strip it. A light sand is all you need to remove the stuff. Howard can be a little OCD. LOL!
Alan's way would work just as well. But? I used standard off the shelf from Home Depot. Can't remember the brand but it came in a spray can. They had 2 types and both worked just as well. (Not the Orange enviro friendly crap though).
BTW is burns wear gloves. (Kinda like sticking your finger in an electrical socket. You only do it once.)
definitely needs re-sealing. I used dupont system clear and color. west to fill voids and blueprint.
Nice looking hull!
What do you mean by blueprint?
make the sponsons even on a level surface to each other.
Cat-Boi you have some nice boats!
