Results 1 to 7 of 7
Thread: Recomended prop for mini hydro?
    PA
    505
    Default Recomended prop for mini hydro?
    What 1/8" shaft prop should I use for a mini hydro 16" long with 35amp and 3600kv? Not sure bout pitch and such. I'm lost here.
    PA
    505
    Oyyyy nevermind. I feel like an idiot. I think I found what I need to decide.
    Sep 2009
    HI
    1,679
    I'd start with a 27-32. Try some of the plastic ones sold here to get an idea. I use a x632 and a v932 on my 17.5" hydro. The 35mm heats thing up too much.
    PA
    505
    These at the top? I figured my rpm would be too high. Since reccomend 10-25k. I have a 3680kv X 11.1V = 40848rpm
    http://www.offshoreelectrics.com/pro...led+Propellers
    Anywhere else where I can find 1/8" shaft props that I don't have to balance and sharpen.
    Sep 2009
    HI
    1,679
    I run an Feigao 8l on 3s. I have started with the plastic ones but broke most of them. I would get metal. They do cost more but if I was to add up of all of the plastic props I broke. I could of bought two metal ones. I have a custom V935 that was cut down to 32 and that prop flat out hauls!
    Sep 2009
    HI
    1,679
    BTW These are the plastic ones I'm talking about. They're for 1/8" shafts.
    PA
    505
    Oh I see couldn't find them before. Thanks.
