Here's a quote from Rumrunnerracing article
The angle of the strut is even more critical. This is what makes the boat run like a prop riding hydroplane. You will probably want some positive angle in the strut around 1-3 degrees (positive angle is when the back of the strut is lower than the front) Too much positive angle and the transom of the boat will bounce violently on it's tail. Too little positive angle and the back of the boat won't get off of the water. This dragging around the pond is hard on equipment. The motor can't unwind so it overheats and eventually will fail, plus the boat will be dog slow. I always error with a little too much positive angle, it helps the boat get through the corners faster
http://www.rumrunnerracing.com/artic...scalehydro.htm
