Peter, The VS1 comes with the stumble blocks already factory mounted. When you get my hull and get the motor and electrics dropped in, you will see what this boat can do! It turns on a dime! Mike
Excellent!
opinions on this lower unit please....is a cavitation plate a must?
no one have an opinion on no cav. plate?..........is that a no no.......really
could use some feedback on this k&b modded outboard
you can hurt my feelings i can take it
I've never used one so cant be sure but I would have thought that if you have it mounted up high so it operates in surface drive mode I cant see how a cavitation plate would be of any use.
I seem to remember a discussion of this on the IW outboard forum, but I can't locate it. If you post the question there I'm sure you'll get some answers. What I do know is that quite a few REK users have trimmed it off to run larger diameter props with good success, apparently.
