Results 1 to 18 of 18
Thread: Turnigy Monster 2000 help
    Sep 2007
    Co
    3,915
    Default Turnigy Monster 2000 help
    While I have been building my 1/8 Pro Boat I have been working on a friends boat that will be running in the district. It is a Dumas Circus Circus 1/8 wood kit, with my HWD. the KB motor, a Turinegy Monster 2000 esc on 8S2P Turinegy cells.
    I just tried out the ESC and I can not get it to reverse. I reversed the servo in the transmitter in throttle. position to reverse. Nothing happened. I had done the initial start up in reverse. I tried to shut off and re calibrated it nothing changed. I still comes on when you break it.
    Pictures of the boat and parts thought you all would like to see.
    Randy
    BBY Racing
    Jun 2007
    5,190
    Randy have you programed it with the specific program card for that ESC
    Douggie
    Sep 2007
    Co
    3,915
    Quote Originally Posted by Flying Scotsman View Post
    Douggie
    No, I do not have one.
    Randy
    BBY Racing
    WA
    2,038
    I'm trying to sort the sequence out here Randy. Your trying to reverse the throttle setting on the ESC? Instead of just switching 2 motor wires? That speedo does not have a reverse setting if you are seeking a forward and reverse setting like some do. I know I'm not getting it to really be of any help.
    John
    Sep 2007
    Co
    3,915
    No, not the diredtion of the motor. The direction of the throttle, from full on to full break it works correctly.
    I want it to go from netural to full on normal. I think I need a Pisitx to start off with after wright ing this.
    Randy
    BBY Racing
    Sep 2007
    Co
    3,915
    I just installed and RC Hydros Pistix and it works correctly! good news. Now I have to get some more for my friend.
    Randy
    BBY Racing
    Dec 2008
    BN
    857
    [/QUOTE]
    hey Randy
    Is that a watercooled outrunner motor?its look so big
    Sep 2007
    Co
    3,915
    Quote Originally Posted by Mel279 View Post
    hey Randy
    Is that a watercooled outrunner motor?its look so big[/QUOTE]
    Yes it is, I have two to sell and one in my Pro Boat.
    Randy
    BBY Racing
    2,726
    How do you keep it watertight with the strut on the inside? any close up pictures, i had assumed a fixed strut attached to the bottom, but that looks like a regular adjustable strut just attached to the inside of the transom rather than the outside.
    Sep 2007
    Co
    3,915
    RTV sylcon on both sides of the bottom and deck tape on the top check out my Pro Boat build it has pictures.
    Randy
    BBY Racing
    May 2007
    SG
    39
    Hi Randy,
    I am interested in this motor also. May I know the KV of this motor??? It looks similar to the one Littlescreamers are selling.
    I am running a NEU 2215 2Y motor with 750kv wif a Octura X455 prop and 10S lipo.
    What would you suggest the prop size to go with this motor?
    Sep 2007
    Co
    3,915
    Quote Originally Posted by Adrianli View Post
    Hi Randy,
    Yes I am a little screamer dealer. This motor has 650Kv I have two in stock, about ready to test in a 1/8 Pro Boat.
    Randy
    BBY Racing
    Jan 2009
    CT
    126
    What ESC did you use and will it handle 6s?
    Aug 2008
    7,080
    thread here seems to be off topic of OP, but I didn't want to start another thread on this ESC.
    Does anybody know if it can be programmed with the TX? I have an order on programming card, but out of stock...
    Anybody have a digital set of instructions or know what the default settings are?
    thanks
    J
    "Look good doin' it"
    See the fleet
    Jun 2007
    5,190
    Jesse, Yes, but you do need a Pistix. I will hunt and see if I have the instructions and will email them to you, if you wish
    Douggie
    Aug 2008
    7,080
    That would be great Douggie, thanks. geohead73@hotmail.com
    I was told by Jason that my Spektrum 2.0 should be able to handle the pistix problem... he said he got his to overcome the issue.
    See the fleet
    Jun 2007
    5,190
    I have found the instructions and will email them in pdf format within 5 hours
    Douggie
    Aug 2008
    7,080
    You rock. take your time, the ESC isn't even here yet - main reason was to see if I needed to do any programming or if it was set to what I will be using. I appreciate the effort!
    See the fleet
