Results 1 to 9 of 9
Thread: Little unstable on right turns
    Nov 2009
    CA
    1,969
    Default Little unstable on right turns
    Hi,
    Did a couple of runs with stock setup, plus X642 prop (picture shows a 440/3, but I swapped it out). I'm using the modified trim tabs (dogears) and fins. Boat is still a little unstable on right turns. We are probably going 1/4 to 1/2 throttle on the right turns, but if we start to power out of the corner she'll bounce around quite a bit and we need to back off. Left turns seem smoother.
    Check out the tab/fin alignment and let me know if these look ok, or should I try bending the fins even further out (this set of fins/tabs actually came from Jesse's old boat, that way I can return to stock setup easily on this boat).
    Thanks,
    -Chief
    PS, X642 is much better than 440/3 on this boat. No cavitation problems when pulling up to plane.
    Nov 2009
    TX
    538
    Try bending the fins out more. Here is a pic of Darin's boat with the handling suggestions that you or previous owners have done. The turn fins look bent out more that yours. If I remember, Jesse also modified it to where the batteries could go all the way back to the transom, so you might try moving the batteries toward the front a little at a time till you find the right COG. Moving them forward will make it ride a little "wetter" and increase the stability. Mine turns at full throttle but too quick a turn will make it hook.
    Nov 2009
    CA
    1,969
    Quote Originally Posted by lectriglide View Post
    I'll give that a try. But I'm wondering if maybe vertical fins combined with the dogears on the trim tabs might work-- I know on deep vees the fins should be // to the keel, but the bottom of the fastech is actually flat-- which makes me wonder it that's the reason it comes stock vertical...
    Anyway, I'll experiment with different configs and report back.
    -Chief
    Nov 2009
    TX
    538
    Read this thread first. According to Darin (Pro Boat Race Team) leaving them stock won't handle worth a darn.
    https://forums.offshoreelectrics.com/...ead.php?t=8080
    May 2009
    ON
    3,180
    Quote Originally Posted by BHChieftain View Post
    Hi,
    Thanks,
    -Chief
    Generally this boat will be little wigily on right turns. It did this to me also. She is great in left turns but I know I know..... Check on Jesses mods to fix this but stock will just be like that .....
    DJI Drone Pilot
    Canada
    Nov 2009
    CA
    1,969
    Default Working great!
    Bent the stabilizer fins out a little more to be perpendicular to the keel. What a difference-- she is running fantastic now. Here's a pic of the fin setup, and a video of our run today.
    http://www.youtube.com/watch?v=5yuSD4ARCw4
    -Chief
    Jan 2010
    ca
    5
    Thumbs up nice adjustment
    I had the same problem with mine. I loosened the out drive and adjusted it up as far as it would go. I was going to buy new turn fins, but seing yours I will try bending mine as well. Great idea!!!!!
    Nov 2009
    CA
    1,969
    Quote Originally Posted by never2much View Post
    Credit goes to Darin! Note, try to get them perpendicular to the keel. On mine, you'll notice the left fin is bent out just a tad too much-- the right one is spot on.
    -Chief
    Nov 2009
    TX
    538
    Chief
    Looking good. If you really want some fun, try a couple 2s lipos. It'll make you
