We will be getting some of these to test in the Spring. They are not totally finished in development yet. This Cat is 36.8" long, has a 36mm x 74mm motor and 90A ESC. Designed to run on 4S rather than the typical 3S setups. A twin is also in development.
We don't have a final ETA for these yet but take a look and let me know what you think!
Genesis Catamaran Specs.
Length:935mm 36.81 inches
Width:230mm 9.05"
Hull material:Fibgerglass
Power:3674 KV2770 Brushless motor with water cooling system(installed). 90A ESC with BEC
Propeller:P1.4*D38 Nylon
Drive system:4mm flex cable,drive shaft,teflon tube,brass tube.drive dog and prop nut.
Radio:2.4G 2CH(not included)
Servo:S3003 (not included)
Power required:14.8V 4000mAH LIPO battery(not included)
