I am looking for a brushed ESC that can handle two 550 brushed motors.
It is for a neighborhood kid with a Clod Buster.
I was thinking about a Astro ESC.
Larry,
I'll do some digging. I think that I still have a new 212D in the shop.
I'll let you know,
John
"When too much is just right!"
I was just going to post this. $ 30 shipped USPS. If it doesn't work out with John, let me know-B back later- [ Astro 212D-25 volts max 75 amps]
Tony
Thanks for posting too Tony. We all have enough of the older stuff left laying around!
Larry,
Not only did I find the new 212D, I found 2 used ones (212Ds), and 3 207Ds. There was even a Tekin 432M in there, and I even dug up 2 brand new SS1s still in the tubes! Man, I should dig out the old boxes more often! NA!
Let me know if you are interested in an ESC and I'll post or PM pics, I'll follow Tony's lead at $30.
FYI; I had seen your post earlier on the red site where you had already found one. Let us know if it falls through.
John
HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
I found a ESC.
the 432M will run two motors.
ONE battery input NOT two.
I have a Manual (432M) in PDF format if you need one.
The Astro and the R/C Hydro's will handle 2 motors.
There advantage over the older 432m is that the 432m
has manual adjustments on the controller that can drift
out of adjustment.
Thanks Tony, BTW it is British Columbia, Canada. Baja Cali would be nice, never been there.
Neal, the 212D tested out fine. I'll include a series harness with deans for the batteries. You'll have to wire the motors to the output side & install some shrink over the SC. BTW this is the SC I used to set the 2006 NAMBA LSO record. PM me with your addy. I'll take paypal or check in the mail.
Tony
http://www.youtube.com/watch?v=u6ZIi2X1eHU
Larry,
I still have almost a dozen NIB V90-1032/Opto controls around here.
Andy
Spektrum Development Team
