Results 1 to 11 of 11
Thread: Can I still run two dif. Types of batts with thesame mah rating. Both nimh??
    86
    Default Can I still run two dif. Types of batts with thesame mah rating. Both nimh??
    I think itwill be ok it just would be riskier with lipos
    Dec 2009
    SA
    18
    When you mean two different types of batts, do you mean running the botat on one lipo and one nimh?
    86
    Oh sorry I wasn't clear I mean brands. I know for lipos u should have same brand,C rating, and same mah. I don't think it will matter for nimh batteries though. I'd still like to here what you have to say
    Dec 2009
    SA
    18
    Oh, ok. Well it kinda depends.
    Is it just the brand that's different ostia the mah etc different?
    Dec 2009
    SA
    18
    *or is it
    86
    The brands the mah is the same which I listed but do u think it would be ok for a run?
    Dec 2009
    SA
    18
    I've tried two different bands on the black Jack and it was fine. All the electronics on the black Jack are the same to the fastech so It should be fine As long as the mah and c rating are the same.
    86
    Ok these aren't lipos though so no C rating but thanks I'm sure it will work:)
    Dec 2009
    SA
    18
    Oohh Sorry, my mistake. I thought you were talking about lipo.
    With nimh it should be fine
    Good luck!
    86
    Thanks.
    Jan 2008
    Mo
    2,716
    Short runs are fine. Just watch your lowest mah pack.
