Page 2 of 2 FirstFirst 12
Results 31 to 54 of 54
Thread: New BJ Owner without maiden voyage
  1. #31
    Dec 2009
    Va
    53
    Thanks.
  2. #32
    Dec 2009
    Va
    53
    Today i went on the Kamchia river to try the lipos for the first time - awesome speed, double than Ni Mh. Will post video soon. Speed was enough for the operator to lose it off sight.
    I start from there, where the engineering thought intend to stop. The sky is just a border between
  3. #33
    May 2009
    3,180
    ...now you are talking.....
    Great news.....
    Robert
    DJI Drone Advanced Pilot
    Canada
  4. #34
    Dec 2009
    Va
    53
    This is the place where i ran the boat yesterday
    Very nice and calm place for vacation.
  5. #35
    Dec 2009
    Va
    53
    fresh video from Kamchia Resort
    http://www.youtube.com/watch?v=aeEcr7tuh-I
  6. #36
    Jul 2009
    5,669
    Quote Originally Posted by snaychev View Post
    Lookin good. It seems as if it may be running a little wet. And dont be afraid to run that thing.... let it rip!
  7. #37
    Dec 2009
    Va
    53
    Damn it is fast like a rocket !!! With the new prop this boat is totally different!!! Thanks to "Egneg" for the perfect job
  8. #38
    Dec 2009
    Va
    53
  9. #39
    Va
    4,670
    The boat seems to be running great - you did a good job with the setup.
    IMPBA 20481S D-12
  10. #40
    Dec 2009
    Va
    53
    Quote Originally Posted by egneg View Post
    Thank you "egneg".
    On the last run i did race with Aquacraft V24 gasoline version 54" - that boat is capable of speed 60 km/h maximum Is she too slow or i am too fast ???
  11. #41
    949
    That looks more like it, now it looks like it's chaseing a storm, nice work.
    are you going to upgrade your hardware soon?
    I must have been looking at the wrong vid when you asked me about how fast your running,
    well after seeing this vid i'd say somewhere about high 36 and 38 and maybe low 39,
    my best is still 39.7 and still playing with set ups.
  12. #42
    Dec 2009
    Va
    53
    With Track Stick Data Logger the result is 92.6 km/h - about 50 mph.
  13. #43
    949
    WOW!!! What am I doing wrong?
    What do have your programmer set to?
    mine is on
    lipo
    timing on high
    cut off high
    set to slow down
    I wonder if I should set it to idle not slow down.
    on slow down it saids it will run at 50% power, is that when the batterys start to run down or is that at 50 % power all the time, if that is the case then thats why its only running at 38-39 mph, what do you think?
  14. #44
    Dec 2009
    Va
    53
    My card is set to :
    Li-Po
    Cutoff voltage- High
    Cutoff type -slowdown
    brake- off
    timing -low
    throttle - linear
    But: i had my stuffing tube broken down from the hull when the securing bolt of the u-joint was loosed and broke the hull from the vibrations.
    After the repair i put the new prop and WOW what a speed.
    Also after the repair i have more space between the tube and motor - about 5 or 6 mm moved to the transom i think.
  15. #45
    949
    Ok thanks, my timing is set to high vs yours at low, I guess i'll keep playing w/strut, prop,and cog and see what I get.
    I'm running 5000 mh 40-50c lipos
    stock motor,esc
    lowered trays
    x642 prop
    no tupperware
    speedmaster hardware.
    why I cant reach 40 mph I havent figured out YET !!!!!!!, but I will
  16. #46
    Dec 2009
    Va
    53
    This is so nice ! I followed "tiqueman"s advice and removed turn fins.
    What a surprise
    Way better control at all.
    Now i can make turns in wide open throttle without slow down every time .
    Thank you friends
  17. #47
    Jul 2009
    5,669
    Yesterday was a great day for the BJ. I moved the cog back a little bit, made a strut adjustment and cupped the prop a bit. She ran 42.7mph from what was 40.1. Super happy with it.
    x642 detongued and cupped
    (2x) 2S 5000mah 40C Turnigys
    OSE hardware
    no turn fins
    stock motor/ esc w/ UBEC
    No tuperware
    lowered batt trays
    extra flotation
    epoxy laminate hatch
    Quote Originally Posted by G-UNIT View Post
    stock motor,esc
    lowered trays
    x642 prop
    no tupperware
    Wheres your strut and hows it set (ie neutral, neg, pos)?
  18. #48
    Jul 2009
    5,669
    Default Snaychev, per your PM request
    Just has a slight kick of positive and the strut is as high as it can go in the factory slot. This position on a S/B/DT and C x642 produced 42.7mph. The picture actually shows it a tad higher as I elongated the strut adjustment slot, but I lost some mph so it has to be moved back down.
  19. #49
    Dec 2009
    Va
    53
    Thanks a lot mate
    Will change my setup as yours and will try asap.
    But as i can see from the picture , you have some kind of bushing out of the strut (between the strut and the drive dog ???) What is that made for?
    In my setup the drive dog is exactly after the strut?!?
  20. #50
    Jul 2009
    5,669
    No bushing or anything there. I think your just looking at the shaft. I see in your picture you do not have that gap. Make sure your running a few mm gap between your strut and the drive dog. This gap allows for the cable to "wind up". Looking at yours, as the cable winds, its pulling the drive dog into the strut and going to cause a lot of unwanted friction and rob you of speed and power and eventually something will fail.
  21. #51
    Dec 2009
    Va
    53
    Quote Originally Posted by tiqueman View Post
    There is a 1,5 mm gap with 1 mm teflon washer between the strut and drive dog.
    Everything is moving freely at WOT under loaded prop.
    Thanks again mate.
  22. #52
    Jul 2009
    5,669
  23. #53
    Dec 2009
    Va
    53
    I just came back from the lake
    She is flying
    Big thank you to "tiqueman" for the information.
    Just two clicks to the positive angle and it is a totally different boat. But today i realized that if i keep WOT in all the way turning (does not matter left or right) she is stable as rock solid Water was perfectly calm like a glass.
    And last of all i made a cover for the hull
  24. #54
    Jul 2009
    5,669
    Glad to hear yo got it all worked out. They are pretty fun boats once you get all the faults out of them.. Still not perfect.. but much more fun than out of the box. You will find that when running w/ someone, it will want to roll over now and again... Ive found if Im running against another boat, if I move my cog just a tad forward, it will help it stay planted.
