Page 1 of 2 12 LastLast
Results 1 to 30 of 45
Thread: Best Whiplash Lipo Location
    Jun 2008
    GA
    2,318
    Default Best Whiplash Lipo Location
    I'm ready to build my Whiplash 20 powered by a NUE 1515 1y and was wondering where is the best location to mount Lipos for best balance. I thought about using these two 30c 4s 3700mah packs wired parallel for a total of 7400mah. http://hobbyking.com/hobbycity/store...idProduct=9506
    These fit very easily in the 4" x 4" location I have outlined in red. Is there a better option?
    Jun 2008
    GA
    2,318
    I also have two Hyperion G3 packs (4s 3300mah) that are very close to the same size that I use in my UL-1 powered by a Nue 1515 1y.
    Nov 2007
    6,927
    Myself and others in our club are running two 2S 4700-5500's in series. You'll have to add dead weight with anything less! The lipos fit great right up front. Look for the Whiplash Builds on this board.
    Mini Cat Racing USA
    www.minicatracingusa.com
    Jul 2008
    NZ
    954
    I did mine a little different, Motor right up the front and cells behind, I can get good cog on 4 and 6s setups like this
    Matt.
    FE, Nitro and Gas racing in Auckland
    www.rcboats.co.nz
    Aug 2007
    693
    Where were you going to put the motor in front of the lipos or behind ?
    There is alot of boat behind the sponsons and you will need to keep as much weight near the front
    May 2007
    co
    1,973
    First remember Brian recommends the CG at 1 inch behind the sponson with a RTR weight of 5lbs this will change the heavier the boat is.
    In my opinion there is 2 much weight in the nose with 4s2p, it handles the corners poorly actually loses speed, I tested it, 2p did not go back in after the first run.
    Here is how I set my Whiplash up: 4s1p 6500mah Hyperion cells, Neu 1521 1.5d. hydra 240 set at low timing, water cooling on the ESC ONLY, it weighs 7lbs 7oz on the water.
    This boat finished overall 3rd at the 2009 Nats in P Sport hydro,not bad for a boat I finished 1 week prior to Nats and had very little tuning on it!
    The Whiplash is my favorite boat!
    Jun 2008
    GA
    2,318
    Jeepers,
    I will mount my motor about the same location you mounted yours in picture. That way I can use the side locations like yours or up front in front of motor
    Dec 2008
    WI
    989
    I did a significant amount of CG testing with mine, and found that the packs needed to be as far forward as possible. I used 2 x 2cell 5000mah 30c packs in series in mine. If you look at the link below you will see that I still had to add 3oz of lead to each sponson tip to get the CG close.
    When you get to the point where everything but the top decking is glued on, install everything and play with the layout until you get close on the CG. I'd be willing to bet some $$ that your packs will end up in the front as far as possible.
    Pic https://forums.offshoreelectrics.com/...4&postcount=58
    May 2007
    co
    1,973
    Quote Originally Posted by detox View Post
    I also have two Hyperion G3 packs (4s 3300mah) that are very close to the same size that I used in my Nue 1515 1y powered UL1.
    this is what I would run If I had them!
    May 2007
    co
    1,973
    Jeepers,
    I will mount my motor about the same location you mounted yours in picture. Thet way I can use the side locations like yours or up front in front of motor
    Even built this way its still a tight fit, the cells hardly fit next to the motor and the sides of the boat. 4s2p does fit on either side of the motor and the hatch does close over 2 4s 5000mah Poly RC packs.
    Jun 2008
    GA
    2,318
    LuckyDuc, Have you ran your boat yet. I have been following your build, but it hasn't been active for awhile now. I especially like your idea of using the UL-1 motor mount.
    Maybe I will put one lipo pack beside the motor and one pack in front of the motor? Never know until I run hull on water.
    Dec 2008
    WI
    989
    I still have some more work to do on mine, so no water testing yet.... I got too busy with work and life
    I plan to get back to it after the holidays
    Raydee did quite a bit of testing with his and confirmed that the CG needs to be around 1" behind the sponsons to keep stability at 60+mph speeds. BUT like you said. It is hard to know until you run it.
    Jun 2008
    GA
    2,318
    Quote Originally Posted by crabstick View Post
    crabstick,
    Thanks for your input. I may try it your way, but one thing that worries me about your motor being so far up front is driveline vibration. It seems that the longer the drive cable the more vibration no mater how much grease I use? Wouldn't a shorter stuffing tube and cable run smoother and vibrate less? Anybody have the answer? What is the best way to prevent a vibration free drive train other than perfect balance?
    Nov 2007
    AK
    310
    Hi Detox,
    I have sen people put one 4S pack up the front in the nose, motor where Jeepers is, and 1 2S pack under the deck where the fuel tank is, and then another 2S pack on the opposite side.then you have the 2 x 2S packs in series, then parrallel with the other 4S pack in the nose.
    Hope this helps,
    Ty.
    Jun 2008
    GA
    2,318
    Quote Originally Posted by tylerm View Post
    Hi Detox,
    Hope this helps,
    Ty.
    Wow! That would be alot of lipo capacity
    Dec 2008
    WI
    989
    crabstick,
    RE: vibration on longer drive cables... Many of the nitro racers mount the motor flat and put an "S" bend in the stuffing tube to reduce flop and harmonics. I have also seen some use additional strut bushings inside the stuffing tube itself and at the motor end.
    Nov 2007
    6,927
    I'm working on mine now. two 2S Hyperion 5500's up front. They are HEAVY. Still need some nose weight! It will be even worse with my Flighpower 5000's....much lighter. DANG! Boat is built and closed up. too late for weight in the sponsons.
    Mini Cat Racing USA
    Dec 2008
    WI
    989
    Quote Originally Posted by sailr View Post
    Yep. It is hard to get the forward weight on this hull. You could drill a small hole in the bottom of the sponson tips and add BBs and epoxy. Then seal the hole up.
    Nov 2007
    fl
    664
    My batteries are 4" back from the nose..bulkhead is removed, Mine is also lsh power although I'm not sure if that matters
    Boats don't win races, drivers do.
    Nov 2007
    fl
    664
    Are you trying to get 4s2p in there?
    Jun 2008
    GA
    2,318
    Quote Originally Posted by highndry View Post
    Yes. For longer run times using the Nue 1515 1y motor. For LSH class I will have to use 4s1p to be legal. How well does your LSH Whiplash run?
    May 2007
    co
    1,973
    Quote Originally Posted by LuckyDuc View Post
    And Raydee said his boat has always ran wet I believe.
    May 2007
    co
    1,973
    Dont put the weight forward add the weight on the CG. Directly on it, it works good!
    Nov 2007
    6,927
    I may have to. I added 3.5 oz. in the front of the tub today and still enough. The other alternative is to move my servo way forward.
    Mini Cat Racing USA
    Nov 2007
    6,927
    That would require an enormous amount of weight!
    Quote Originally Posted by Jeepers View Post
    Mini Cat Racing USA
    May 2007
    co
    1,973
    not as much as you think!
    May 2007
    1,603
    My 2 cents is get the cells as far forward as possible. Anything less and the butt end will drag around the pond. My cells are now way up into the nose of the hull with the motor right behind them and it is the best running hydro I have ever owned. It will run wide open all the way around the pond and will turn like it is on rails at 60mph. My Whip was built a little heavy to withstand some abuse so it did run wet at first but once I figured out how to properly load a 1515 1Y on 4s it became a water rocket.
    Team Liquid Dash
    Apr 2009
    69
    Default Whiplash 20 Lipo
    Quote Originally Posted by Raydee View Post
    Kit just arrived and build is starting. My basics are Neu 1515 1Y on 4s. What prop are you using to properly load the motor and where did you locate the 2s2p or 4s1p cells?
    Thanks for the info:
    jesflorida
    May 2007
    1,603
    This is where my cells are, and the motor is right behind them.
    Team Liquid Dash
    Apr 2009
    69
    Raydee:
    ]Thaks for the schematic, very helpful.
    Are your G3lipos 3300 mAh or something else?
    Can you tell me about your prop?
    Thanks again,
    jesflorida
