Page 2 of 2 FirstFirst 12
Results 31 to 42 of 42
Thread: 34" Scrath Built Cat
  1. #31
    Sep 2008
    321
    Hi, I used 3/32" on the bottom and 1/16" on the sides and top. Regards
    Norman
    34" Ekos Cat UL-1 Powered
  2. #32
    Sep 2008
    321
    Hi. Used 3/32" for bottom and 1/16" for top and sides all covered with silkspan and
    thinned out fiberglass resin. Regards
    Norman
    Sorry Double post
  3. #33
    Sep 2008
    321
    Default 34" scratch built cat
    Hi, Finally was able to complete painting. Graphics will be ready Tuesday so once
    they are on I will clear coat and install Hardware and Electronics. Regards
    Norman
  4. #34
    FR
    2,096
    Very nice, may be Hydrolift replica?
  5. #35
    Sep 2008
    321
    Hi Alfa Spirit, It is going to have my own graphics similar to my 30" Shake N' Bake
    cat but in different colors. I agree it will look like the Hydrolift. Attached Photo of
    what I am trying to clone. Regards
    Norman
  6. #36
    FR
    2,096
    Nice too, ACME made chrome metal adhesive?
    Can you explain how did you made the rear pipes like Maritmo
  7. #37
    Sep 2008
    321
    Default 34" scratch built Cat
    Hi guys, Got my graphics today and will clear coat in the next few days. Will then
    install the hardware, Motor, flex shaft and prop. All the electronics are in. Bad thing
    is I will have to wait for some warmer weather to try her out. Will post more photos
    when it is completed. Regards
    Norman
    PS. Exhaust were made from basswood and copper tubing from the local hobby shop.
  8. #38
    Aug 2007
    tt
    102
    Default happy new year guys
    hi norman guys this is the first for the year from me. great job norman can you give me some info on the minwax stuff i use west system epoxy but if i can get some thing cheaper it will be great.i am close to finishing my 31 shockerman cat got all twin drives just needing two esc' looking at 9xl best recomendation.also need some balsa shop info the shop here in trinidad wi does not have the 1/32,1/16 skins any help will do.thanking you guys rawson reyes.
  9. #39
    Sep 2008
    321
    Hi Rawson, Welcome back to the forum. The Minwax product I used on the new cat
    is Fast Drying Clear Satin Polyurethane. It is easier to use than fiberglass resin
    to seal the frame and hull. Only drawback is it needs about three coats to do the
    job. Our local hobby shop carries all sizes of balsa, plywood, and basswood. I would
    suggest you go to the Tower Hobbies site and they carry all sizes and types. Hope
    this helps. Post some photos of your build. Regards
    Norman
  10. #40
    Aug 2008
    7,080
    Well Norman, you have out done yourself! Amazing work and quite speedy as well.
    Cheers, Jesse
    "Look good doin' it"
    See the fleet
  11. #41
    Sep 2008
    321
    Hi Jesse, Thanks. I had to build a bigger one than my
    30" incher in order to get more space for the electronics.
    My fingers are too big. I just hope it runs as good as the
    other one which is now a static model. What are you building or planning. Regards
    Norman
  12. #42
    Sep 2008
    321
    Default 34" Srctch Built Cat
    Hi, Finally finished my 34" cat. Now to wait for spring until the lakes are no longer
    frozen up here in Western North Carolina. First I am going to power it with and
    extra Ammo 36-50-2300 which I have lying around but finally I ordered an Ammo
    36-56-1800 which will be the final set-up. Have not decided on ESC but will probably
    be an Etti. Octura X640 Prop and 4S Lipos. Hope you like it. Regards
    Norman
