Hello I have recently acquired Diegoboys Mini Hydro and need some help tuning this thing. I have no hydro experience so go easy. I got the boat to run a straight line well it just wont turn. You have to really creep through the corners. It seems to be stuffing the left side in the water at speed in the turns. It currently has no turn fin. Need some advise on placement, size etc on the fin.
Heres the current setup.
Total lenth is 17.5"
C.O.G. is at 2 7/8" behind the rear of the front sponson.
Here are some pictures. The last ones are where I think the turn fin should be. Due to the size of the hull would it be okay to mount on the hull and not the sponson? Its tight in there and the ride pad is way in. Should I space it out or should I run it as close to the hull if it's okay to mount it there?
Thanks George
