I think the only real way to get an accurate evaulation would be to dyno each motor being considered.
Devise a base load to put them each under, and evaluate the results based on that data.
I've already done that for the 4 subject motors for P-Spec... That's why they are on the list and appropriate. I ran them each unloaded and loaded, using a standard 4S pack for power, and a standard SV27 ESC for control. This gave solid baseline and consistent numbers from which to evaluate from.
I think that, if anything else was to be considered, it would need to undergo the same testing. However, I do think that we need to limit the list to JUST approved motors and to a VERY few of them... Otherwise, it's just P-Class Lite, and what's the point...
The idea was to have a place where RTR boats and those just getting started could have a place to come play with the rest of us... If you start putting in motors that are above and beyond the "cheap Chinese" stuff that comes in the RTR boats, then you're blowing the class up... and again, what's the point...
Darin E. Jordan - Renton, WA
