Darin,
I have some thoughts & "seat of the pants" info to share on the Scorpion 3026/1900. After seeing one in person in Jan's DH, and watching it perform,I bought one. First, I installed it in the VS-1 which was using a Hydra 120 [ v1.04 with timing set to low- 4.75 deg. advance]. Same prop as when the UL-1 motor was used; Grim 42/55. No big increase. M445 - no big increase. M545 -cogged. Put the UL-1 motor back in the VS-1. Put the Scorpion in the UL-1 with a CC BAC 80. M445- no big increase. Put the Scorpion back on the UL-1 with the UL-1 SC and the Grim 42/55 and performed on par with the UL-1 motor. Haven't tried bigger props yet to try out the potential for using the supposed more torque. Apparantly, I've heard, the UL-1 SC has more advance [ possibly 11 degrees-according to what Greg Schweers told me] and I'm hearing that the Scorpion likes advance. Of course, as you've observed, a big wheel on an OPC can cause some issues. My conclusion is that the Scorpion for OPC, at least, won't create any unfair advantage.
On the subject of "max watts" maybe this analogy might dispel what seems to create an unfair comparison: Loudspeakers have max watt ratings. Take one rated at 100 watts and one rated at 200 watts. This rating is what they can [I]handle[I] before voice coil deformation. With the same amplifier power, the 100 watt speaker will actually likely play louder. A 150 mph/rated tire will go just as fast as a 200mph/rated tire on the same car. The way I interpret the "max watts" rating on the motors is what they CAN put out before degradation. The Scorpion may just be built to Take more, not PUT OUT more. That's my read, anyway.
I'm not trying to advise here, just giving my 1.5 cents. I'm usually wrong anyway ! Plus it looks like I need to shell out more dough for a Blackjack motor [which now looks like the "flavor of the day"] to race LSO in AZ next month and I'm running out of money
