What is a good prop for the mini rio ?
  • lucozader
    • May 2009
    • 144
    an octura
    x 427
    x 430
    x432
  • thegreat1
    • Jul 2008
    • 249
    what is you setup?
    • lucozader
      • May 2009
      • 144
      brushless and lipo
      • thegreat1
        • Jul 2008
        • 249
        what is the size in mm of the motor and also what is the kv rating?
        • lucozader
          • May 2009
          • 144
          2600 KV brushless motor
          Specification: Length: 40mm (exclude motor shaft)
          Width: 20mm
          Shaft size: 2.3mm
          • damfurst
            • 261
            with that size motor I would think the x427 would be best. You could try the x430 but you would have the check the motor temp & esc to make sure you don't burn it up. Also, that size motor won't fit in the motor mounts on the mini rio, but you might be able to shim it someway. It definitly would need to be water cooled too.
            • Jesse J
              scale FE racer
              • Aug 2008
              • 7116
              I just ran mine today with a 3000KV outrunner on 2S with a 432 and it rocked. motor came in at 55deg F...
              "Look good doin' it"
              See the fleet
