Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 121 to 150 of 213
Thread: Swordfish ESC's
  1. #121
    May 2010
    TN
    26
    I just bought the Swordfish 120 on Wednesday so I don't need any more info on the SeaKing comparison.
    Earlier, m4a1usr recommended that if you have an auto timing setting, which we do, leaving the timing alone. That was my plan.
    Has anyone tried a switching frequency on these ESCs other than the default 8kHz? I see we can pick 12 and 16 as well.
    I'm going to be running 6S on a Neu 1415/1.5Y (1500kV, 4-pole) if that makes a difference. My goal is not maximum speed, but to keep everything running the coolest.
    Thanks.
  2. #122
    Jan 2010
    4
    Default Proram card issues
    Steven, having trouble getting 240V Swordfish to accept program from the program card. Have 6.0v pack connected to the two bare power wires on the harness, red/black/white connected according to polarity on back of program card...other end of harness connected to ESC. Leaving ESC off, turning on 6.0v power source and I get the red light on the program card. Then turn on the ESC, get a green light on the bottom of ESC. Press the "transmit" button on program card and nothing happens. No motor or lipos connected to the ESC (assuming I don't need that). The instructions that came with the card say the red light should blink twice when programming complete. Any suggestions?
    BTW I checked and my battery pack is delivering right at 6.0v so I don't think that's the problem.
  3. #123
    Jan 2010
    4
    Got it to program, the polarity is flip flopped in the Y harness, causing the card to not program. When I plug the harness into the ESC throttle control backwards, I'm able to get it to program. On the wires, for me that means Brown to White, Red to Red, and Orange to Black.
  4. #124
    9,402
    What radio are you using?
  5. #125
    Jul 2010
    3,663
    Quote Originally Posted by marcelaw View Post
    Mine is the same way. If you have a SF240 just pay attention to the wires rather than the plug. I'm not sure if all the plugs are consistantly backwards or if its just some so best bet is to go by the wires.
  6. #126
    Nov 2007
    6,927
    Are you saying the socket in the program card is wired backwards? Or do they provide you with a Y-harness that's backwards?
    Mini Cat Racing USA
    www.minicatracingusa.com
  7. #127
    Jul 2010
    3,663
    Quote Originally Posted by sailr View Post
    Its the y-harness. I plug the esc into my receiver as I would any other esc.
  8. #128
    Nov 2007
    6,927
    I see. I don't have one of their esc's so I guess they send you a Y harness with it? I've always plugged the esc directly into the program card on all the other brands. No need to have it plugged into the receiver usually. I guess the Swordfish is different.
    Mini Cat Racing USA
  9. #129
    May 2008
    OH
    774
    Solved my problem above, the 12 year old Schultz took out a phase in the UL1 motor when it failed. Changed motor and ran it today all's well!!
  10. #130
    wi
    232
    I think you have that reversed. When the motor failed it took out the schultz.
  11. #131
    Jul 2010
    3,663
    I may not have worded that clearly. There is no need to use a receiver to program it, I just meant the plug on the esc is wired correctly.When I put it in the boat and run it, I dont plug it into the esc upside down.
  12. #132
    Jul 2010
    3,663
    Default Swordfish stand-alone programmer
    I just bought the standalone programmer for the SF ESC's. It works great on my 120, but I cant get it to work on the 240. It shows a y-harness in the directions like the one that comes with th eusb link, except it has an extra set of wires for teh rx pack to plug into...so it's a total of 4 sets of wires instead of 3 like teh usb link version.
    How do you get this to work? Steve do you sell a harness for this?
  13. #133
    ma
    8,694
    Quote Originally Posted by keithbradley View Post
    Keith I'm a bit confused. There isnt a separate harness. We might have to contact Hifei about this.
    Steven Vaccaro
  14. #134
    Jul 2010
    3,663
    I got it to work with the y-harness from my usb linker. (It does show a harness like I described in the instructions, but I guess its not needed after all)
    On your site it says to use a 4AA rx pack, so I tried one instead of the nimh 5 cell rx pack I was trying to use with it, and it worked. I checked and double checked the wires on the rx pack and esc...maybe it's just possible the two pin connector on the 4AA style packs makes better connection with the programmer?
    I suppose it's also possible that I turned the ESC on AFTER I plugged it in when I tried it before. I noticed even when using the 4AA pack if I plug it in and then turn the ESC on, nothing happens. It has to be on when you plug in the battery.
  15. #135
    May 2008
    Oz
    2,981
    Controller on 240HV have a 4.5-5.5V tolerance.. outside that range and it will not function... eg 5 cells wont work.
    The SF240HV has no BEC..
    The programmer gains power with 3plug wiring harness from BEC enabled ESCs.. it needs external power for the SF240HV... thus the 4 connector lead
    Assume you plugged 4cells direct to programmer somehow to achieve successful program with 3 plug leads... ??
    details ?
    W
  16. #136
    Jul 2010
    3,663
    You got it.
    I used the y harness from the usb linker, hooking it up the same way I would if using the usb plug only plugged that end into the programmer... then plugged the rx pack into the power port on the programmer. Worked perfectly.
  17. #137
    May 2008
    Oz
    2,981
    If you had used the 4plug lead with 4cells attached it should have worked.
    Ive noticed a lack of QC regarding wire allocation to polarized plugs.
    Meaning.. the plugs when mated have different color wires joining !
    hafta watch these color blind assemblers !
    W
    You got it.
  18. #138
    Jul 2010
    3,663
    Steve is there any replacement discount or anything on these if they go bad? I just fried my SF 120 today. It worked great, but unfortunately I sub'ed my boat and it filled with water. When I brought it up, the esc had shorted and I now have a stinky boat
    It worked great and its totally my fault for getting it wet...just thought I would check and see if there is an exchange discount or anything
  19. #139
    ma
    8,694
    There isnt an exchange discount. But they to warranty them or repair them for a cost. Send me a email and I will send you the return info.
    Steven Vaccaro
  20. #140
    Feb 2010
    1,025
    Default SWORDFISH runs cool!
    Hey STEVEN borrowed Norms Swordfish 240 last weekend to run in my 70+mph 10S1P X-Era O/R powered 44"Open Hydro a London Canada IMPBA race. It was so easy to run no programing`plug and play' always came in around 130 degree range after 7 laps on 1/6 mile course. Very impressed with smooth thorottle response and overall control at factory auto settings. Great controller for the money!
    ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
    ****2008/9 MMEU LSO, 2008 LSH CHAMP****
    ~~~~~~~70 MPH Club Member!~~~~~~~~~
  21. #141
    ma
    8,694
    Quote Originally Posted by K.R.Joye View Post
    Glad you liked it Ken. I have had great luck with them.
    The Swordfish 120 has been outstanding.
    My son and I beat the hell out of a 120 this weekend in his n2 mono.
    He was draining a 6500 hyperion 35c pack to 5% in 170-180 seconds. Right at the rating on that esc and it went as smooth as silk. Previously we had only been able to run a Hydra 240 on that setup.
    Steven Vaccaro
  22. #142
    9,402
    Yee haa, sounds like a keeper!!
  23. #143
    7,279
    Good running boat and based on my "touch test"...quite a cool running controller
  24. #144
    Jul 2010
    3,663
    Your PM box was full but I sent a message through the store site. Thanks for your help.
  25. #145
    Feb 2010
    AT
    4
    Hello
    an easy question can I program the 240 HV with these card:
    http://www.hobbycity.com/hobbyking/s...ramming_card__
    Thanks Albert
  26. #146
    ma
    8,694
    Quote Originally Posted by AustriaAT View Post
    Hello
    Thanks Albert
    It looks quite different than the Hifei model.
    Steven Vaccaro
  27. #147
    Feb 2010
    AT
    4
    Hm
    they write: Compatible with Super-Brain and Monster ESCs.
    And at HK the 240HV is listed as an Aquastar Monster.
    Please help.
    Thanks Albert
  28. #148
    ma
    8,694
    Hm
    Please help.
    Thanks Albert
    Seems like you should give it a shot. Let us know how it goes?
    Steven Vaccaro
  29. #149
    Nov 2007
    6,927
    That is a Hifei aircraft controller card. Not sure if it will work with their marine esc's or not.
    Hello
    Thanks Albert
    Mini Cat Racing USA
  30. #150
    May 2008
    Oz
    2,981
    That card is for the HiFei(Turnigy) Monster2000, the Aero precursor to our new HiFei Swordfish (Turnigy Aquastar) series :)
    Communication interface between card and board are different.... latch sequencing does not match.
    Use at own peril ! .. ( avoid inhaling the toxic smoke )
    This link shows the HC (Turnigy) equivalent for Aquastar... l a relabeled HiFei !!
    http://www.hobbycity.com/hobbyking/s...d_Super-Brain_
    Hello
    Thanks Albert
