Page 2 of 2 FirstFirst 12
Results 31 to 58 of 58
Thread: NEW FASTECH!!! :help:
  1. #31
    86
    hey would it be bad to run my boat in like 100 degree weather?
  2. #32
    Aug 2008
    7,080
    Not if you had a cooler full of frosties. Just keep an eye on motor/esc temp. batts should love it.
    "Look good doin' it"
    See the fleet
  3. #33
    86
    aight awesome....
  4. #34
    Aug 2008
    7,080
    I wish I had the same problem here...... might help the frozen ponds problem
    See the fleet
  5. #35
    86
    yeah its always like 75 here but in lake havasu in arizona its like 115 and the waters like 65. my dad said it would be fine. he i pretty smart about boats cause we also have a deep vee in real life and they are pretty similar. he might try to make some custom trim tabs for the funtech.
  6. #36
    86
    hey so how would i buy the card off you. i have the money...
  7. #37
    May 2009
    3,180
    Quote Originally Posted by p.swiggs View Post
    You have to sent paypal to Jesse. Sent him PM and he will respond with details...
    Robert
    DJI Drone Pilot
    Canada
  8. #38
    86
    Hey guys is my turnfin supposed to shake a lil by hand? Is the props seal supposed to have a lil gap inbetween the outer side of the shaft?
  9. #39
    86
    like by the rubber washer and the prop? i dont think so cause i bath tested it woth no shaft grease and water got in, i think thats what the problem was but im still waiting on grease
  10. #40
    Aug 2008
    7,080
    Did you want to buy the card?
    See the fleet
  11. #41
    86
    Yeah and can u answer my question too
  12. #42
    Aug 2008
    7,080
    I think you are describing the weakness of the stock hardware. Did you look at my Fastech mods thread? I replaced the stock strut and all those silly linkages with a more traditional strut where you can remove the drive line very easily. I would recommend replacing your hardware with a bearingized strut and .150 cable drive with 3/16" stub. this will solve the majority of your problems you are observing. see rcraceboat.com and Jeff Wohlt has what you need.
    See the fleet
  13. #43
    86
    So I lil shakage is ok? I realized the gap problem too
  14. #44
    Aug 2008
    7,080
    probably normal. I know Dad's boat has some vibration.
    See the fleet
  15. #45
    86
    ok alright.http://www.funrcboats.com/images/pro...PRB3800_md.jpg, the prop should be all the way against the the end of the shaft where it goes through and out of the shaft holder. sorry if this is hard to understand im still a newb
  16. #46
    86
    hey i ran my boat for the first time yesterday and it was not what i expected. .. dont get me wrong,it was fun but look only about 15mph.... some water got in so i put some sealant on anything i thught would let water in...yet again i was running realy old 3300 mah 7.4 volts. it was running wet to so that lost speed. im thinkin if i do the trim tabs do make the front ride higher and bend the turn fins out and run some good batts. and a x642 prop i will be about 34mph
  17. #47
    86
  18. #48
    1,969
    15mph stock? Something is not right. I have two fastechs, the stock one runs around 30MPH on two 6cell NiMh packs...
    Are you running the battery packs in parallel or serial? Parallel would be pretty pokey... but you would have needed to modify the wiring to run it that way.
    Be sure that your prop has 1-2mm gap at the strut, as the flex drive will compress under load, and if you don't have that gap, you could be binding the cable.
    -Chief
  19. #49
    May 2009
    3,180
    You need LiPo batteries. Your problem is your old batteries. If you did not change your battery wires and still have stock this boat will get you close to 30 for sure. When you get LiPos than you can swich to x642, for now you need to find out why you not where you should be just on stock. How did you get water in? Was your hatch taped properly? Check for other remarks you got from BHChieftain also.
    Robert
    PS
    Here was my stock with LiPo upgrade only:
    http://www.youtube.com/watch?v=ZfpqdsTSASE
    DJI Drone Pilot
    Canada
  20. #50
    86
    hatch wasnt taped all the way..barely any water in in though. im not worried about that... how do i attach pics?
  21. #51
    Dec 2009
    SA
    18
    hey, Jesse J
    In one of your earlier posts about the 5c for the fastech, how would you balance out the boat? I was thinking of doing this but a 3s weighs quite a bit more than a 2s battery. Where would you place the batteries?
    Thnx
  22. #52
    86
    kk how do i attach photos to show u guys?
  23. #53
    Jan 2009
    ca
    842
    Go to the forums home page and click on the first post, I think it is fast electrics question and answer forum, scroll down to "how to post a picture" and you should be good to go
  24. #54
    86
    Hey guys I tried my boat again with some lipos n nicads some good ones. That boat was doing 30+ n it's all stock. Basically as fast as my buddies sv27 with brass prop. This boat is awesome but it doesn't turn that well even with the steering sharpness adjustment thing all the way
  25. #55
    1,969
    Read this thread-- my boat turns on a dime now...
    https://forums.offshoreelectrics.com/...ad.php?t=12302
    -Chief
  26. #56
    Aug 2008
    7,080
    Quote Originally Posted by Justiniousrowe View Post
    hey, Jesse J
    Thnx
    Take a look at my thread on the Fastech let the mods begin. You will see why I removed the bulky framing in the aft of the boat. You will probably need to put them in sideways or remove some clutter.
    See the fleet
  27. #57
    86
    so around the same speed as a sv27 mean my boat is performing good right?
  28. #58
    1,969
    If you can keep pace with an SV27, you are doing good.
    My son's fastech is about 5-10mhp slower than my friend's SV, but the SV is running lipos and the proboat is on nimh (heavier and lower voltage...). On the same batteries I think they would be darn close.
    I also think the proboat is more stable than the sv (but the SV is a lot easier to seal up for when it does flip over).
    -Chief
