Results 1 to 14 of 14
Thread: timing for the venom motor.
    Oct 2009
    Ut
    45
    Default timing for the venom motor.
    I have a King of Shaves 34" brushless. Has anyone played with the timing? The factory doesnt even know what the stock timing is nor what it should be! They can't even tell me the specs on the motor. Anybody know?
    Jun 2009
    TX
    423
    I played with the timing in all directions and the factory default setting is the best for power/cooling to be in the safe range. I honestly wouldnt go higher in the timing due to the possibility of motor failure
    The RTR Nightmare- Electric King of Shaves
    Now with 540s- 62mph
    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
    Oct 2009
    Ut
    45
    I may have inadvertently changed the factory timing, and venom can't tell me what it is.. What is it? 0?
    Jun 2009
    TX
    423
    IIRC, it is 7*. I'll double check when I get home tonite
    The factory default timing is setting #4 11.25deg. advance. You can use that or setting #1 which is 0deg. but if youuse anything higher you have to watch temps and adjust accordingly.
    Chris
    VENOM RACING R&D
    Jan 2010
    VI
    204
    Now what if your running say colder water such as say 45-50 degree temps shouldn't be an issue at running more advanced timing shouldn't be a problem.
    Jun 2009
    TX
    423
    I wouldnt touch the timing. These motors are tempermental enough, I would just leave it stock. Advancing the timing wont get you much anyways, maybe 1-2mph.
    Apr 2010
    In
    324
    how do you get it back to factory timing?
    Apr 2010
    WI
    12
    I just ran my EKOS with stock motors and 3S lipo in 55F water, after 5 mins at WOT, motors and esc were just above the water temp about 62F. That was at 0 timing, so Im going to go up to the 11.25 this weekend and see how it runs.
    Mar 2010
    ny
    2
    does anyone ekos form venom split on the side
    Apr 2010
    CA
    239
    Quote Originally Posted by scubasteve95 View Post
    ITS VERY EASY
    GO TO VENOM SITE AND CLICK ON THE PICTURE OF THE EKOS
    THEN CLICK DOCUMENTS
    GO TO PAGE 5 AND FOLLOW THE DIRECTIONS.
    I SET MY TIMING TO - 0 ADDED 6 INLETS AND OUTLETS AND
    AM HAVING NO ISSUES ON 4s,BUT,
    (DO NOT RUN 4s ..... JUST BECAUSE IT WORKS FOR ME)
    I'M NOT SAYING DON'T BUT IF YOU DO ITS ON YOU......
    JUST HAVE FUN WHAT EVER YOU DO
    Quote Originally Posted by skater368 View Post
    I AM ALSO CHECKING TO SEE IF THE
    Hobbywing LED Program Card For Brushless ESC Version 2
    WILL WORK,IT WILL BE SUPER EASY IF IT DOES AT ONLY
    $10.70 SHIPPED FROM EBAY
    Nov 2009
    Ca
    2,686
    Your manual has a whole page on how to change the settings from the transmitter. Its not too difficult. You can download the manual from venoms website if you dont have it.
    Apr 2010
    CA
    239
    THIS IS ALL OLD NEWS..
    IT IS EASY FROM THE TX BUT MOST OF THE ESC's I BEEN SEEING
    WANT YOU TO USE A PROGRAMMER JUST TO BE SAFE AND
    SEEING IT ON A SCREEN FOR ME IS MUCH BETTER,FOR
    10 BUCKS TO KNOW I GOT IT RIGHT...I'M OK WITH THAT
    Apr 2010
    CA
    239
    hobbywing programmer works perfect on
    ekos esc's
    took all of 30 sec. to program esc
    led readout and controlls A+
