Search here for PiStix and you might find the answer.
A while back (spring) somebody else had trouble with a PiStix and a Tactic radio. They sent both to me (I designed the PiStix) and it was just a matter of adjusting the tx a little. I think I posted the "how to" here. It might be over on RCGRoups or RCUniverse, too.
Make sure your ESC will arm WITHOUT the PiStix first. You will need to adjust the reversing so it arms properly. Then insert the PiStix and you should be able to arm with the throttle in the center.
And if all else fails, you can send it to me and we'll go through it again. PM me if you get to that point.
Andy
Spektrum Development Team
