Results 1 to 6 of 6
Thread: Octura Aluminum Props
    Jun 2009
    La
    104
    Default Octura Aluminum Props
    Has anyone tried these on a brushless setup? It clearly states it is not recommended for brushless set ups.
    But, im wondering why isn't it recommended?
    Jun 2009
    423
    Aluminum doesnt have the same strength as the beryllium/titanium yada yada stuff that their normal props do..
    Yes but balancing them is not a health hazard as beryllium...
    http://en.wikipedia.org/wiki/Beryllium#Toxicity
    Ql
    328
    Exclamation Ali Props
    Quote Originally Posted by mikesf View Post
    I have used them as test props only.
    Before to long they will blow a blade off from the stress.
    Cool
    The aluminum has more negatives than positives for BL power.
    - The blades cannot be sharpened enough and the result is non-optimal performance - prop walk, low efficiency.
    - The castings are porous and don't polish or smooth well
    - The weak nature of the metal can result in easily-thrown blades - dangerous!
    - Aluminum is not without its own health concerns - it is a known neurotoxin. I'd rather have berrylium poisoning (treatable) than alzheimers!
    http://www.med.nyu.edu/patientcare/l...hunkIID=164929
    http://www.angelfire.com/az/sthursto..._toxicity.html
    Bottom line - follow the manufacturer's recommendations.
    Jun 2009
    La
    104
    Thanks, i figured it was a strength issue, just wondering if there was anything more to the reasoning.
    Thanks.
