Page 3 of 7 FirstFirst 12345 ... LastLast
Results 61 to 90 of 188
Thread: New catamaran project
  1. #61
    Jul 2008
    WA
    772
    Quote Originally Posted by CornelP View Post
    One suggestion for these HiModels: watercool & change the capacitors, they are way to small for this capacity...
    Or just add more caps
    an RC rock crawler lost in a sea of boat parts.........
  2. #62
    May 2009
    RO
    745
    Been there... the original ones are a bit of a suspicious origin. But yes, adding more will take the strain from the ones fitted.
  3. #63
    FR
    2,096
    I' m waiting for motor, cooling jacket and aluminium motor mount from rcworldwide.com.hk, they aren' t very fast ...
    Now, I' m preparing the hull: reinforcement inside, tight box filled with floating material, exhaust pipes , and soft design modifications ...
    After I' ll do the paint job
  4. #64
    FR
    2,096
    Quote Originally Posted by ozzie-crawl View Post
    that may work, if you can run your stuffer tube all the way into the strut
    That work fine with bigger teflon washers and brass tube inside the strut, That' s perfect. With the Graupner drive dog I can use 3/16" propellers without adapter
    I think that' s the best solution for HOTR 4mm strut. Easy, cheap
  5. #65
    1,453
    i had a crack in my 4mm and caused the shaft to spin in side the square , so i got a octura 3/16 bearing drilled out the strut and and installed, very easy to do and no adapter and easy to remove shaft to clean, just like every other setup is
  6. #66
    FR
    2,096
    The XPower 540 XL / 3674 11 turns, 1510 RPM/Volt arrived today The motor looks a very high quality
    Aluminium motor mount from RCworldwide is a very nice part
  7. #67
    FR
    125
    Hey,
    Nice to hear news from you,
    Any updates on the build?
  8. #68
    FR
    2,096
    I whent to RC shops but I didn' t find carbon. So I bought fiber glass layers and epoxy.
    I' ll first reinforce the joint around the hull and after the bottom and sides with two thicknesses of fiberglass
    The aluminum rudder from HOTR was badly mounted (inverted). Now it' s OK, All screws are on the same side and rudder is perfectly perpendicular to the cat
  9. #69
    FR
    2,096
    XPOWER 540 XL BRUSHLESS DATA SHEET
  10. #70
    Jan 2008
    Mo
    2,716
    Gee, the 8XL is the same specs as Feigo. I wonder how close they are? I do like the pinned motor end.
    Where dio you get this from? I have seen several distributors.
  11. #71
    FR
    2,096
    I bought mine here . Those motors are made by FSD Motors
    http://stores.shop.ebay.fr/rcworldwi...0Q2em14?_pgn=1
  12. #72
    May 2009
    RO
    745
    XPower and Feigao are pretty much the same... at least the same factory. When one of my suppliers placed the order for some XL's, he was asked if he wants Feigao or XP... Actually, if the order is consistent, you could get your own logo and color.
  13. #73
    Jan 2008
    Mo
    2,716
    Yep...FSD or some plant like makes them both.
  14. #74
    FR
    2,096
    Now I' ve got all parts to make a nice job
  15. #75
    FR
    2,096
    I bought an ETTI water cooling plate for my HiModel GX 200
  16. #76
    ga
    45
    wow man the boat looks great! and dang that motor is massive!
  17. #77
    May 2009
    NJ
    356
    how much was the etti cooling including shipping?
  18. #78
    Aug 2008
    3,071
    Quote Originally Posted by norbique View Post
    $13 plus shipping which i think is $9
    http://www.offshoreelectrics.com/pro...prod=etti-a044
  19. #79
    FR
    2,096
    Quote Originally Posted by Alfa Spirit View Post
    I paid 14 €uro including shipping cost to France, here' s the link
    This is the large sized
    http://cgi.ebay.fr/ETTI-Wasserkuehlu...item43956f2d90
  20. #80
    FR
    2,096
    Quote Originally Posted by winner View Post
    Thanks, All parts: hull, ESC, motor, .... are cheap but are matched
  21. #81
    FR
    2,096
    Hi,
    I' m not sure that flex/shat coupling will be strong enough.
    I think to reinforce the end of the square flex cable with strong glue Is it a good idea? Thanks
  22. #82
    Nov 2008
    CZ
    136
    Default Prop
    Hi Alfa Spirit,
    your project is very impressive for me. Im going to build this cat either.
    On picture above i can see very nice prop in fitted in graupner DD. As i remeber, graupners DD has outer dia. 10mm and to props seem to be perfectly aligned with DD. Octura has about 8mm hub dia. So i prefer props like yours. Where does your prop come from?
    Thanks, Cugi.
  23. #83
    FR
    125
    Hi,
    Now I' m working for nice paint job I will do the paint job before components assembly
    it will hold just fine, glue will not add to its strenght ,
  24. #84
    FR
    2,096
    Ok, thanks Elvish
    The aluminium propeller is a USA brand may be AMPS or something like that. No brand on the prop, only 2029
    My cat project is a cheap RTB and I' m pretty sure it will rock
  25. #85
    FR
    2,096
    Hi,
    I want to order propellers for my cat' I hope you can help me.
    Cat' HOTR, 6S batteries and motor 540 XL 1510 RPM per Volt
  26. #86
    FR
    2,096
    OCTURA X440/3 or X447/3 ?
    Which one will be the best for my setup? I really want to order 3 blades propeller
  27. #87
    UK
    370
    I understand what you mean.
    I will install a brass tube 4mm inside and 5mm outside, approx. 15mm long. Like this the shaft won' t move, only a small amount of play
    Hi,
    I have just modded my original TFL strut because I might be getting the dual motor set from e-bay, The problem with this is that it runs 4mm stingers and I want to use 3/16" prop's...
    I turned down a piece of oil-lite brass 4mmI/D and 4.762 O/D. It's a lovely snug fit now and runs true.
    I think this is the way to go if you want to use 3/16 props on any 4mm shaft.... IMO!!
    HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
  28. #88
    FR
    2,096
    Hello guys, I' ve found an interesting product from 3M : Thermally conductive pads. It' s not expensive , very easy to work with. Advice please
    3M Thermally conductive
  29. #89
    May 2009
    NJ
    356
    Very interesting! I'm just modding a 100A mystery ESC. I sanded the FETs flat and I will glue the heat-sink on them with a thin layer of JB Weld.
  30. #90
    FR
    2,096
    I' m waiting for 2 pads thermally conductive from 3M, price is 4 € / piece :
    Here are the parts for direction channel Very clean.
