I don't know i p[ut a flex cable and turn fin and all on the apache 24 I am thinking the boat hull stinks..I bet i put it in another hul and it goes faster.
Hi i have a digital unit that measurs RPM for my slot cars and the titan 12 is way faster you can hear the sound of them both with hooking the 3300kv up with a battery and flooring it with just the motor only and then do the same with the titan 12 it screams and revs much faster.
for the 3500 it depends some motors i hear are rated differently it should hit the 20's .
lipos have alot more punch over nimh, but those can be used
You will love the results with lipos!
I have some nimh batteries, and all they do is take up space on my shelves..
I just placed my order through tower for the sv27!!! pumped, cant wait
I seen a pic of that one as well, they may becoming out with 2 new boats then. The one we seen and maybe a brushless vs1 rtr. That would be sick, I won't be getting another one for a while! Wife is a little angered I spent over $400 at tower today all i heard was O well lol
What new boats?
https://forums.offshoreelectrics.com/...ad.php?t=10729
The link is for the posible FE VS1 and im not sure what the proto hull is called
here is the mini cat..
http://www.aquacraftmodels.com/boats/aqub19-main.html
I'de love to see a FE VS1
I was doing some reading on the SuperVee and came accross something that said that 2 8.4v 7 cells were to much for the bec and burning out the rx and that if using anything other than 2 6 cells nimh you should use a rx battery box. Did anyone else hear about this or is anyone using larger than 6 cell batteries on their supervee.
I never got higher than 2s lipo but they do sell electronic becs if you need it this way you do not need to carry the extra battery weight.
Also i am runnin a Carbon Fiber 45mm prop with your batteries i would use the CF 42mm prop the 45 may heat your packs up to much... Reason why i am saying to use these props they work way better than the stock SV prop the stock prop cavatates and the boat takes for ever to get on plane but with the CF props the boat pops right up out of the water and takes off like a rocket!
Thanks, I will look into those props. I just ordered the SV adjustable trim tabs from OSE. Do you use these? I also ordered the port side turn fin. I'm trying to make this boat as stable as I can, I'm not the best driver in the world
http://www.offshoreelectrics.com/pro...od=ose-tab1015
Do you think I should run my 6 cell 3300s? Instead of the 7 cell 4600s?
