Page 3 of 12 FirstFirst 12345 ... LastLast
Results 61 to 90 of 358
Thread: Motor Mounts
  1. #61
    Sep 2009
    HI
    1,679
    Heres a shot of mine. Gonna try sumtin different. Should be finished soon.
  2. #62
    May 2008
    AB
    1,465
    Thats lookin good George
  3. #63
    Apr 2010
    3,480
    Peter, I have a 1527 1.5d w/OSE can I'll be attempting to put in a Genesis catamaran. Do you have a mount that would work?
    ________
    Toyota kluger specifications
  4. #64
    May 2008
    AB
    1,465
    This is the only 15XX cat type mount I make ......would this work
    https://forums.offshoreelectrics.com/...1&d=1254756138
  5. #65
    Apr 2010
    3,480
    Quote Originally Posted by Peter Zicha View Post
    I think I need more of an angle out of the motors mounting position.
    This is the application:
    ________
    Herbal Vaporizers
  6. #66
    Apr 2010
    3,480
    I have the boat here if there's any measurements needed.
    ________
    GROW MEDICAL MARIJUANA
  7. #67
    May 2008
    AB
    1,465
    If you make your own stringers to bolt the sides of the mount to you could mount it at any angle you want , the picture doesn't show it but that mount has the sides drilled and tapped for setscrews
  8. #68
    Apr 2010
    3,480
    OK, that will work then! PM Sent!
    ________
    Mazda Rx-7 Picture
  9. #69
    Oct 2008
    9,488
    good stuff!
  10. #70
    May 2008
    AB
    1,465
    Aaron here is your mount + 5" servo plate
  11. #71
    Sep 2009
    ME
    1,332
    peter , looks amazing..top shelf work..i cannot wait to score a 2230 for it..thanks again
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  12. #72
    Dec 2009
    la
    1,078
    Quote Originally Posted by bonewar View Post
    Hi Peter,
    Well i finally finished the mount for your CNC piece.
    I thought you would like to see the finished product.
    Came out very nice.
    Thank you !!
    Cheers Bonewar
    Which mount is this? Looks like the flat bottom mount only the pics don't show it can be mounted from the sides. Was that a custom request? I'm looking to do something identical to that with a 1521. Pics shown in original post I'm linking below.
    https://forums.offshoreelectrics.com/...1&postcount=33
    Catching Air!
  13. #73
    Jan 2008
    AU
    549
    Talking
    Quote Originally Posted by johnf View Post
    Johnf,
    Mate the mount is for the Neu 1521, 1527.
    It comes as a flat mount with mounting holes on the lower sides .
    I used 4mm carbon plate to make a angled mount for the CNC mount to sit on.
    I then checked the carbon mount into the floor of the cat and glass it into place.
    The CNC mount sits on the carbon mount and is held in place with 4 bolts.
    Came out very strong, and also looks good.
    A couple of pictures to show you what i'm talking about.
    Bonewar
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
  14. #74
    Dec 2009
    la
    1,078
    Thanks for the info bonewar! Looks fantastic, as do all your other projects. I couldn't see any holes in the pics punisher posted to mount from the side like you did. I'm looking for a nice way to mount a 1521 in the insane hydro I'm having built. If you check out the thread, markf has a 1527 shoehorned into his. Looks like the motor just tucks into the hatch. Tight on clearance from what the pics show. I'm hoping this mount set up like yours would fit under the hatch.
    Catching Air!
  15. #75
    Jan 2008
    AU
    549
    Talking
    Thanks for the kind words my friend,
    Send Pete your idea and between the 2 of you guys
    i bet you'll come up with a perfect solution.
    Pete's mounts are very well made, and the look awesome in the hulls.
    Good luck with your project mate.
    Bonewar
  16. #76
    Dec 2009
    la
    1,078
    Thanks bud. I agree, they look amazing.
    Catching Air!
  17. #77
    Apr 2008
    LA
    1,510
    Peter I would like a quote for a Lehner 3060 mount, 5 inch rails with esc plate add on. Thanks
    T. Hatch
  18. #78
    May 2008
    AB
    1,465
    Is this for a cat or a mono
  19. #79
    Apr 2008
    LA
    1,510
    Sorry Peter its a mono. DF41 its shown here with a 2215/2y and ESC is a Schultze 40/160.
    Edit: I mentioned ESC "Plate". I prefer the Heavy Duty mount you have with the water cooling tube braces built in to the motor mount. That looks sweet.
  20. #80
    May 2008
    AB
    1,465
    That option was only specific to the cat flat bottom mount but could easily be added to the V-mono mount also
    A 3060 in a 41" mono is bordering on overkill..............I like your attitude
  21. #81
    May 2008
    AB
    1,465
    Larry this is a little screamers face plate I just did for a mono hull , yours will be much like this but with a flat bottom
  22. #82
    Apr 2008
    LA
    1,510
    Quote Originally Posted by Punisher 67 View Post
    Excess is a neccessity when all you do is race against yourself!!!
  23. #83
    Apr 2008
    LA
    1,510
    Peter I sent you the e-mail. Still yet to hear frrom you. I hope all is well.
  24. #84
    May 2008
    AB
    1,465
    I am very sorry but I haven't received anything , can you resend it just in-case it was my fault I missed it.........................
  25. #85
    May 2008
    AB
    1,465
    Ron here is your 2280 mount , I still have to drill the esc plate and side mount screw holes and mount the stainless steel setscrews
  26. #86
    That looks awesome! I dig it!!
  27. #87
    May 2008
    AB
    1,465
    Ron and Larry
    here are your mounts , they were mailed out a little while ago
    tth......... I have email you twice now I am hoping you recieved atleast one email
  28. #88
    Apr 2008
    LA
    1,510
    I did get the last one with pics attached. I will be in contact with you in a bit. Thank You Peter.
    TTH
  29. #89
    May 2008
    Oz
    2,981
    Peter.
    Im after 2 x basic medium for 1521s in rigs.
    What is width of mounting plate ?
    Please lmk details.
    costs
    wait
    etc
    Wayne
  30. #90
    May 2008
    AB
    1,465
    Hello Drwayne
    if you are talking about the optional ESC plate that sits on top of the mount it is a shade under 2"inches wide , the 1521's go in the basic medium and the base width is 2.75"inch but I can make that whatever width you want
    If you need two I should be able to get to them sometime late next week hoping that is not an inconveniance . Prices are on the first page + $7.50 to ship anywhere in north america
