Page 2 of 2 FirstFirst 12
Results 31 to 43 of 43
Thread: Delta Force 33 47MPH flip
  1. #31
    ca
    6,963
    Almost done. Holes are my hardware's "signature" ; as my driving skills in racewater leak out of the hole in my head on the driver's stand every time
  2. #32
    May 2009
    3,180
    I am glad to see you are enjoying yourself and that the checkered babe is getting some racing action. I just felt bad keeping her cramped up in the shop collecting dust. Great work Robert!
    J
    Thank You Jesse... This boat I like...
    Winter time we have Delta Force nock off project going.. ha....
    We=Me, Doby, Daniel
    DJI Drone Pilot
    Canada
  3. #33
    May 2009
    3,180
    Can't wait to see this on my boat....
    Thank You...
    DJI Drone Pilot
    Canada
  4. #34
    ca
    6,963
    Done. PM your address & I'll get it out tomorrow.
  5. #35
    May 2009
    3,180
    Wow, that was fast...
    DJI Drone Pilot
    Canada
  6. #36
    May 2009
    3,180
    PM sent...
    DJI Drone Pilot
    Canada
  7. #37
    May 2009
    3,180
    Any chance for few pictures in order for me to get the boat ready if I need it?
    Cheers
    Robert
    DJI Drone Pilot
    Canada
  8. #38
    ca
    6,963
    Robert, the four outermost holes should line up perfectly with yours. I got the bracket from Ray with the innermost holes drilled, but the four outside holes are standard Speedmaster spacing. [ I had to drill the inside holes to line up with the holes on my boat which had the standard spacing ] You'll have to back out the two inside stainless clamping bolts to get access/clearance to mount the bracket, then screw them back in once the bracket's mounted to the boat transom. I threaded [cut threads] to the inner bracket to make this easy. You may have a clearance issue with your water line, maybe not. If the new bracket interferes with the trim tab, grind the bracket [or trim tab] some.
  9. #39
    May 2009
    3,180
    Robert, the four outermost holes should line up perfectly with yours. I got the bracket from Ray with the innermost holes drilled, but the four outside holes are standard Speedmaster spacing. [ I had to drill the inside holes to line up with the holes on my boat which had the standard spacing ] You'll have to back out the two inside stainless clamping bolts to get access/clearance to mount the bracket, then screw them back in once the bracket's mounted to the boat transom. I threaded [cut threads] to the inner bracket to make this easy. You may have a clearance issue with your water line, maybe not. If the new bracket interferes with the trim tab, gring the bracket [or trim tab] some.
    Roger...
    DJI Drone Pilot
    Canada
  10. #40
    ca
    6,963
    Just mailed it including customs declaration. Hope it gets there soon
  11. #41
    May 2009
    3,180
    So fast, thank you!
    DJI Drone Pilot
    Canada
  12. #42
    May 2009
    3,180
    Everyone!!!
    Please have a look at this e-mail and respond!!!
    I hope Jim do not mind me placing this respond for all of you to see it...
    Re: Shippment
    Quote:
    Originally Posted by LiPo Power
    Hi
    Thanks for sending this so quickly. How much was it and how do I pay you back please?
    Robert
    No payback needed. Glad to help. If someone else needs a favor you can help with, pay it forward.
    Tony
    __________________
    2006 LSO Record Holder
    2008 P-Mono & P-Offshore 2-Lap Record Holder
    2009 P-Sport Hydro 2-Lap Record Holder
    DJI Drone Pilot
    Canada
  13. #43
    May 2009
    3,180
    Default DF-33 Custom Rudder Bracket
    Tony
    Bracket is here now. Thank you for your help again. Looks tough. I will have one more chance this season to test it out before my boat will sit on the shelf to wait for another.
    Cheers
    Robert
    DJI Drone Pilot
    Canada
