Results 1 to 13 of 13
Thread: broken u joint?
    Oct 2008
    ky
    240
    Default broken u joint?
    so has anyone had a problem with the Flexshaft w/ U-Joint: breaking ? i have had two break this week? running 2s 3700 lipos and a x645 prop and everything else is stock???
    Jun 2009
    to
    58
    that's wierd I run 5s and it doesn't breakwhere is it breaking and is your steering to extream and the u joint binding the. snapping
    Jun 2008
    896
    that's a lot of prop. that'll be your problem. time to upgrade the drive or prop down to an X642. Even then you'll probably break it in time.
    Oct 2008
    ky
    240
    so is there an upgraded shaft????
    Jun 2008
    896
    Quote Originally Posted by jlr3rd1 View Post
    you'd have to go with all new hardware to get rid of the steerable outdrive. Fullers is a very popular choice.
    Oct 2008
    ky
    240
    ok thanks :) going to do something this just not working:)
    Jun 2009
    to
    58
    fillers is the best option I would read all fourms about the hardware because there are more then on option also the skater system
    Jun 2008
    896
    this is a nice looking system too for a great price.
    http://www.offshoreelectrics.com/pro...prod=ose-80085
    Oct 2008
    ky
    240
    thats looks good but will it work because of the 3/16" Propeller shaft? instead of the 4 mm shaft?? or do you need to modified the shaft assembly ?
    Jun 2008
    896
    your x645 is 4mm? I thought they were 3/16.
    Jun 2009
    to
    58
    if the prop hole is bigger then the dog drive and shaft use the stock prop insert to make up the diffrence
    Oct 2008
    ky
    240
    the prop shaft size is 3/16 so i have to use a shim that goes from 3/16 to 4 mm:) so that way it will fit my bj and sv :)
    Oct 2008
    ky
    240
    here are asome pic s of my bj :)
