Page 2 of 2 FirstFirst 12
Results 31 to 38 of 38
Thread: K7 Bluebird
  1. #31
    Sep 2012
    Tg
    1,441
    Hi Paul
    I was reading an article today about the Bluebird is going to be fired up and run again soon. New jet engine in it but they only plan to run it around 65mph, not 300. The article popped up on FB but I couldn't find it again to get a link.
  2. #32
    Nov 2008
    Ql
    3,169
    H Pete. Thanks.
    I knew that the restoration was nearly complete. But I didn't know when the first test run was goung to be. I'll see what I can find out.
  3. #33
    Nov 2008
    Ql
    3,169
    A bit more done on the K7.
    Fitted the motor, strut, rudder & driveline.
    Glued & screwed on the sponsons, then added the balsa leading & trailing edges to the spars.
    A bit of filler, sanding & primer. Now she's ready for the famous Bluebird blue paint.
  4. #34
    Nov 2008
    Ql
    3,169
    Well that's weird. Don' t know why they all came out upsidedown.
  5. #35
    Nov 2008
    Ql
    3,169
    Computer is finally fixed, thanks to fellow boat racer, Pete.
    So now I can post a bit of progress.
    Finally got a coat of blue on it. It's actually a hi temp brake calliper enamel. Nice tough, glossy paint. Straight out of a rattle can.
    I'll sand it back & give it another coat. Then a test run.
  6. #36
    7,633
    All right Paul, since you posted a link here... how is the Bluebird doing?
  7. #37
    Sep 2011
    BA
    296
    https://www.facebook.com/profile.php...0Y&pnref=story
    There are many pictures there.
    I found browsing the web. They do not belong to me.
  8. #38
    Nov 2008
    Ql
    3,169
    Hey buddy.
    It hasn't changed much from the last post. Pathetic really.
    But I have found a pilot that will pass as Donald Campbell. All I really need to do is glue him in, & glue the canopy on. And add a bit of aluminium trim paint on the sponsons & the exhaust cone.
    Then it is a matter of adding all the hardware & motor etc back onto the boat & she'd ready.
    It's just that so many other things keep getting in the way. I will make a concerted effort to finish it before I start the next boat.
