What’s the best prop for this boat?
i bought a prop from dasboata and deff noticed a diffrence, but today i hit something in the water and damaged it. i wonder how the stainless steel one from doctorprops compares. i would think that its stronger but i haven't seen any comparison reviews. Its from the ukraine though but they ship worldwide 7 bucks it says 15-30 days.
Well I'm not going to wait that long and want to keep my business local as possible I'm ordering another dasboata prop
I am curious on this one too, it seems to be a big secret on what props are fast and what props are great at cornering and acceleration. I mean I know the difference between a 2 vs. 3 blade. What I am referring to as a secret is the actual prop models and manufacturers that people are running to achieve their flaunted performance.
"Flaunted performance" :olleyes: ....You must be referring to my videos of mine. It's no secret what prop I run to go the speed mine does. It's the dasboata "Supersonic prop" we call it. Hit him up and he will sell you one or put you on the waiting list for one if they are out of stock. dasboata@aol.com is the best way to reach him.
https://www.youtube.com/watch?v=aHfFIkukKWo&t=64s
https://www.youtube.com/watch?v=mlhg8ESVuVQ&t=3s
Lol.. I dont mean flaunt in a negative way.. sorry if I implied negativity. Also, I dont mean you. You have stated multiple times where urs came from. I inquired to Chris about 2 props for my previously stated intentions. He then sent me an invoice for 110 for 2 props shipped. I'll pay it when I can swallow the sticker shock ( a.k.a. get a prepaid Visa card to hide the purchase from my wife) hopefully this coming week. I guess I am just use to the surface guys who post and share every detail of their builds and specs of parts used. The boating world seems to be more secretive with their setups. Is a "custom prop" made from scratch? Doubt it.. if I had to guess it's a 20.00 prop that been sharpened/balanced maybe polished too? I'm not sure..
Lol...No worries.
The "best" prop for this boat depends entirely on your performance expectations and from the videos I have studied I came to the conclusion that this boat is too over powered and does not perform very well right out of the box without a lot of fine tuning. My preference is to have a setup that allows for fast oval runs on 6s without the boat bouncing or flipping all over the place uncontrollably so I opted for a lower pitch prop in an effort to tame the beast. I wound up using a Grim Racer 42x55 1.3 pitch prop from one of my Revolt 30's and my Sonicwake's been running great without issue all Summer long. It probably isn't hitting 50+mph but a simple prop change turned it into a fun, fast and very stable sport racer.
Its called the Supersonic3 prop from Dasboata! I just ordered one today matter of fact so I can break my personal best with my SONICWAKE PROBOAT.
My boat is all stock except for a Sonic2 prop swap for my 2nd run to achieve 90kms
https://www.youtube.com/watch?v=O0Zd-nuxr_o&t=170s
Hi I have a few left in stock , I also stock props that settle this boat down without quite as much speed buy more enjoyable to drive !!!!
hi i got a sonicwake for x/mas. i had lots of problem right out the box .the flex cable unwound, servo stop working, rudder mount bent, the mount for the servo broke, so i upgrade all broken parts .new servo mount. stronger push rod ,25kg servo, ,dual water intake rudder, bigger water lines, ran two line to the esc, added a thru hull pick up for the motor cooling,
So Now the boat sails or runs perfect when turning left. but when turning right the motor seems to sound louder and the boat slows down. i'm new to the hobby 1st boat. and i was wondering if anyone has had this problem with there boat . or is there a fix. Thank you
Please tell it came w/ some sort of warranty that from where ever you bought it so you can send it back?
I love my SW!!
First, I'm new to RC boating...so new, in fact, that I don't even have a boat. Note, not new to RC (have a dozen off-road & on-road racers, a few off-road bashers, and a few crawlers), just boating. I've been researching what boat to buy (V vs cat, and model options), with my current most likely possibility being the PB SonicWave 36. At the same time, as with anyone new to the hobby, I'm somewhat "clueless" in the area of upgrades. I don't plan on doing massive upgrades from the get-go, but I know certain ones should be done as quickly as possible. Obviously, the rudder should be swapped for a dual pickup, such as the OSE Dual Pickup Rudder Blade Kit. Having been involved in RC for a while, I realize that the ESC, motor, and servo should be on that list. I've already figured a Hobbywing Seaking ESC, and probably a Leopard motor (could use suggestions/recommendations), plus either a Hitec or Spektrum servo (again, coujld use suggestions/recommendations...tho, Spektrum servos are known to sometimes have problems with Futaba receivers). Two upgrades I have absolutely no clue about are the prop, and the flex cable. Regarding the flex cable, I'm assuming that the OSE HD Flex Cable would be a good option, but is there any others I should consider?
Now, the primary reason I posted this here, and did it as a reply to your post, is because I was already figuring dasboata as the supplier for the prop, but I feel I don't need something as fast as what MADRCER got...but, when you mentioned, "I also stock props that settle this boat down without quite as much speed buy more enjoyable to drive", that seriously peaked my curiosity. Can you provide the part number (in here and/or via PM)? Better yet, if I werfe to order the flex cable & prop from you, would you be able to install the prop (obviously, for a fee)? That's assuming that the prop can be installed onto the flex cable before installing the flex cable into the boat...again, I have no understanding (yet) of these things...but, I do enjoy taking things apart, and learning how to put them back together.
I do have one final question, which is, indirectly, related to the prop...and that would have to do with the drive mechanism. Is the stock drive "good enough", or would something, such as the TFL Integrated Drive System be considered a good upgrade? Thank you, in advance, to any reply/replies than are given. Looking forward to joining the "water crowd".
If your first boat will be a Sonicwake I would get used to it in its stock format first for at least a while until you get a good feel for it and how things work before spending a lot of $ on upgrades as it's a pretty good boat right out of the box. I had great success with mine on 6s and ran it for a whole season last summer without a single issue however I did not like how it was performing with the stock prop so I changed it for a lower 1.3 pitch prop of the same diameter. See my post #7 above for details.
Dasbota has an excellent reputation for making props so see what he recommends. I have purchased some props from Doctorprops in the past and they are beautifully crafted and well worth wait.
I would not recommend the TFL Integrated Drive System as an upgrade as you are limited to a 36mm motor size. The stock drive train is fine.
FE boats are like potato chips...you can't have just one. Good luck and happy boating.
As much as I REALLY like Pringles, I understand what you mean. As for the TFL integrated drive, whether it's SonicWake or Pursuit, copy...scratched off list. If I go with the SonicWake, I'm thinking it's still a smart idea to replace the ESC with a Seaking, as well as installing the dual pickup rudder.
For the ESC, it's a matter of determining which - 120A or 180A - is the better/smarter upgrade. The price difference between them is minimal enough that I can go either way. I'd think the 180A would be more efficient, and should run cooler, but that's something those familiar with it can tell me. Anyone? The only reason (understanding what little I've learned) I might decide against the 180A is because of the LVW mentioned by a few people (3 years ago), where they mentioned the "low voltage" didn't always work correctly. Has this been corrected (via formats update), or is this still a problem? Between these two ESCs, which would be the better choice? Are there any other ESCs that should be considered (especially if they're better than the Seakings, but not overly priced)?
In regards to the dial pickup, I know I could just install a 'Y' on the stock line, just inside the hull, and then run the lines to the motor & ESC...but, I'd think the dual pickup would be more efficient, allowing the ESC & motor to run cooler. Again, a boater newb...but, having custom-built computers for 25+ years, I do have considerable understanding of "liquid-cooking efficiency". You can still use a single reservoir, but using separate pumps & lines to individually cool the CPU & GPU is the smarter way to go. I can't tell you how many times I've had to convince gamers of this (they typically want the highest-powered, fastest, computers, for the lowest price...and then they want to overclock them to the point of killing the CPU). I'm looking at the boat from a similar perspective - the ESC & motor are, to me, the equivalent of a CPU & GPU. Am I correct in the dual pickup being more efficient, and keeping the ESC & motor cooler?
Sent from my SM-N975U using Tapatalk
I have a few TFL boats, two Pursuits and a Rocket and all have Seaking ESC's and I can say they have been 100% reliable for me and the LVC kicking in early has not been a problem. As far as I know the 120 amp Dynamite ESC in the Sonicwake is made by the same manufacturer as Seaking and can be programmed with a Seaking program box which is what I used to program my Sonicwake ESC. If you want to upgrade I would suggest the 180 amp Seaking but I don't see any real need for it unless you are going to install a larger 40mm motor.
As far as a dual pickup rudder is concerned it certainly can't hurt but I have not experienced any overheating of any of the components running stock on 6s with the exception of the lower pitch prop I mentioned. I don't have a GPS but I would say I'm running in the high 40's and the boat handles very well.
I see you have been posting over on the RC Groups forum as do I. They are a very knowledgeable bunch as well.
The TFL Pursuit some members have been suggesting would also be a very good choice and in my opinion it will handle better at higher speeds than the Sonicwake will. I like my Sonicwake for what it is but It's no Pursuit in terms of its handling capabilities at speeds over 50mph.
So...I ordered, from Steve, the 'OSE upgraded' SonicWake today (already have the tracking number). I'll still be getting the Pursuit, once he had them back in stock (he said approx 8wks, which is partly why I decided to get the SonicWake...I can be running it before the end of the week). It comes with the dual pickup & HD flex cable already installed. Coming from Steve, I'll assume the cable is well-greased, but I'll double-check, just to be certain (for the few RTRs I own...all land vehicles...I always check certain things before I start running them).
To start, I'll be replacing the Rx with a Futaba Rx (which I'll place inside a Traxxas waterproof Rx box), plus I'll only be running 4S...preferably in 2x 2S, but I need confirmation whether two packs will fit, side-by-side, and what the maximum dimensions of each can be. Eventually (ie. after I replace the ESC, probably with a Hobbywing Seaking 180A...again, I could user suggestions/recommendations), I'll run 6S, but I feel 4S is a good place to start.
As for the prop...will be contacting Chris asap, to determine the best options. I'll definitely want a speed increase, but I also want to maintain stability.
Hey Panther great choice ordering from Steve. Pretty much any standard sized 2s pack will fit side by side just make sure it has a c rating of 50 or better and a minimum of 5000 mAh. Personally I use 70 to 90c 3sx2 packs 5400mAh. Just to give you a rough idea on size they are 51/2 " long x 11/2 " wide and 2" high. 4S will give you a pleasure cruise so you can probably prop up a bit for more speed just watch the temps as 4s will draw more amps. I've also seen videos of the boat running stock on 5s and it was quite stable but I love the sound of this boat on 6s power hence I went with a lower pitch prop. I also purchased a 440/3 blade from Doctorprops which I'll be trying out this summer.
Happy Sonicwaking.
In post #6, you mention using the Grim Racer 42x55 1.3 pitch. I can't remember if it was you, or someone else, but I do remember someone mentioning using a CNC-4514 from OSE (actually, I think a few mentioned this, in multiple threads, in more than one forum). In the end, I decided to order a couple of the CNC-4514 props from Steve. Some of the things I really like about Steve, and OSE, is excellent customer service, and (super) speedy replies to email. Steve is, most definitely, customer-service driven. As long as I remain in this aspect of RC, and as long as Steve is in business, he has me as my #1 'goto' for boats & boat parts. Additionally, if anyone asks me about RC FEs, and inquires where to go, I will be directing them to Steve, and OSE.
Unfortunately, by experience with Chris, and dasboata, was the exact opposite. Unless requested by others, I will try to refrain from posting the actual PMs...but, in short, he has shown himself to be rude, arrogant, and lacking the decorum to provide good customer service. He may very well be a "professional" where making props is concerned (I can't claim to know, as he chose to be 'negative' towards me, when I inquired), but even Circuit City provided better costumer service. I contacted him about a prop for the SonicWake. He replied back, saying he had a prop, and quoted a price...and that was all he said. I messaged him back, asking for the missing info, as well as a few questions ANYONE new to the hobby might ask (part number, what metal, pitch, how to pay, etc)...and he purposely ignored it. 1-2 days later, I inquired about a reply, and that's when he responded back, with the rude & arrogant reply mentioned. As I said, I won't post specifics (unless requested by others), but I can tell you that his reply was rude enough that I shouldn't have given him a second chance...but, I did. I replied back in as nice a way as possible, explaining how, what I asked, anyone new to the hobby might ask. And, he's ignored that message. Since I've never actually done business with him, I can't say anything to others...but, I will say the probability I'll be purchasing from him is "slim to none".
Steve & OSE, on the other hand...I am MORE than happy to direct my money in your direction. Other businesses could learn a LOT about what outstanding "customer service" truly is.
So you are upset because Chris (BTW Chris is DASBOATA) didn't give you the specs on the prop he offered to sell you when you asked him for a good fast stable prop? Chris don't publicly put out the specs on some of his custom props and here a few reason's why he don't. #1. Because some were developed with my help for my boats and I may have asked him not to give the specs out publicly and for him to just sell them exclusively through dasboata.com under a specific name....#2 Sometimes it takes a lot of time and development to get a prop right for a particular boat and why would someone just give this hard work out for free for others to clone or purchase on their own from someone else or maybe just go and purchase a cnc prop with similar specs on a site like OSE? Prop work is what puts food on the table and pays his bills (aka his livelihood). #3. Imagine all the emails and PM's he gets from people just wanting info and NOT actually planning to buy a prop from him....Betcha it's a lot since proven custom prop guys aren't readily available and not to mention he's one of the best in the business. #4 You might find an overseas website or two that recommend a prop and tell the specs of it and also states "your boat will be the fastest with this prop" but you NEVER see a video of the prop running to backup what the site claims.....I'm not going to put the website on here but I'm sure you can find it if you search around. So why would he want to help his competitors make a dime off him and sell a prop he custom developed for himself or a customer... #5 Ever heard of KFC (Kentucky Fried Chicken)? Do you think people are mad and bash them on forums because they haven't given out the secret 11 herbs and spices of their chicken? Well if they did then they might go out of business, because they would be several more fried chicken restaurant's around selling their recipe that they worked hard and perfected. Anyways hope your cnc props work out for you on your sonicwake.
Obviously, I know Chris & DASBOATA are one and the same...I clearly stated that. I never asked him to publish any info publicly...I asked about some incredibly basic info, and I asked him via PM. The closest I even got to sing specifics was the diameter & pitch...in other words, info that anyone would normally publicly publish. My other questions were asking nothing more than the metal type (brass, SS, or aluminum), and how I was supposed to order/pay. Now, if that's info that someone wants to hide, how do they expect to have customers? Purposely hiding that type of info would be akin to...say...an ESC manufacturer refusing to provide BEC info, or a servo manufacturer refusing to provide speed & torque into. Without providing that info, they can't sell anything, now can they?
I was also up front that I am new to RC FE, so, obviously, it's not as if I was attempting to collect info to make my own, or have someone else make them. As a matter of fact, even after his rude reply, in my reply, I even told him I was actually interested in 2 props. He didn't "lose" a customer...he "pushed" a customer away. I understand he's a friend of yours, and that's all good. I've asked for info, so as to help me learn, you have provided some of that info, and I truly am greatly appreciative for that. As for Chris, if he wants customers, there IS certain info that NEEDS to be given out. There's no need, or reason, to purposely avoid providing info such as the type of metal a particular order is made of, or the diameter/pitch...again, that's info topical found on any site selling the same type of product.
I'm not trying to put him down. More than a few people (yourself, included) have stated about the quality of his work, and I believe that, which is exactly why I turned to him for the props before every checking with anyone else. I was 100% intending to purchase from him, even after his reply. But, when he chose to purposely ignore my reply to his reply, that's why I made the decision to go elsewhere. In regards to outing me away, maybe he can reverse the 'damage' he's caused...but, doing so would require additional effort on his part.. effort I'm not certain he's willing to make. One thing anyone in a customer service-related business mega to always remember is, just as the word of excellent CS can travel to others, so can poor CS. Don't take this as any sort of threat...I promise it's not...but, in taking with other locals, of they've had problems, others do eventually find out. I'm not here to cause problems. Quite the opposite. I'm here to learn, to have fun, and, once I've Haines some knowledge, to help others. Lastly, I'm not "upset" at his actions...more like "irritated".
Finally got her in the water for her "maiden voyages". For right now, the only batteries I have (for the boat) are 2 pair of PowerHobby 2S 5200mAh 50C, and 1 pair of Spektrum 2S 5000mAh 50C (which are packed away, but I'll try to find them today), but I do plan on getting more, & better, packs. I'm strongly considering some SMC 6200mAh packs, but, if anyone can suggest/recommend some others, that'd be fantastic.
Using the PowerHobby packs, she got up to 31.4mph on the first run, and 31.7mph on the second (both, obviously, on 4S). I don't know if that's good, bad, or average. Anyone who can, please, let me know, is greatly appreciate it. Granted, she's still stock...haven't installed the CNC-4514 prop (yet)...with the only 'upgrades' (installed by Steve prior to shipping) being the OSE dual-pickup rudder & OSE HD flex cable). I forgot to bring my temp gun with me, but everything (ESC, motor, & batteries) was only lightly warm, so I wasn't worried.
~ More peace, love, laughter & kindness would make the world a MUCH better place [emoji1690]
Happy to hear your finally on the water with your Sonicwake. Like I said in an earlier post 4s will get you a pleasure cruise. You'll notice a big difference in speed with 6s batteries.
I purchased 2x3s SMC Premium Spec 90c 5400 mAh batteries for mine and so far after running them all last summer they have held up just fine. I think they are offering a version 2 now which are supposed to be even better.
Other batteries I have used in my boats are Thunder Power and Gens Ace and they have all held up very well too. I don't know much about the newer graphene lipos but some members swear by them.
Thanks for the info...can definitely use it. I still plan on getting some more 2S packs...probably 6600mAh, but possibly 8000mAh (additionally weight is negligible, 303g for 6500mAh, 351g for 8000mAh, & 309g for the 5000mAh Graphene), but won't decide how many until I get the boat back in the water, this time with the 4514 prop. If it's a 'great' improvement, I might order more 2S than 3S packs...and, if it's only a 'moderate' improvement, I might order more 3S than 2S.
Looking over SMC's current 3S offerings (that aren't too low/high in mAh), they are:
1) True Spec DV 6500mAh 75C (120A, 455g)
2) True Spec DV w/G10 plates 7200mAh 75C (Amos not listed, 454g)
3) True Spec Premium V2 5000mAh 90C (97A, 330g)
4) True Spec Extreme Graphene V2 6400mAh 150C (Amps & weight not listed, dimensions also not listed)
The 'Premium' is what I run in my off-road race vehicles, and I typically avoid the 'Extreme' (no warranty). For the SonicWake, I was actually considering the 3S DV 6500mAh...slightly higher in capacity (longer runtime) than the 5000mAh packs, but considerable less than the 7200mAh & larger packs that would allow too much heat to be generated. I realize that the 6500mAh packs weight more than the 5000mAh packs (by 27.5%...330g vs 455g), but, with a power output increase of 50%, I would assume that the power-to-weight ratio should still keep the handling characteristics of the boat approx the same, without causing to much of a great increase. Also, since the boat would be moving faster, more water would be passed through the water lines, increasing the cooling efficiency, this countering the slight temp increase caused by the longer running time.
Well...got the SonicWake in the water for her 3rd & 4th runs, this time on the CNC-4514 prop from OSE. On the first 2 runs (stock prop), if I remember correctly, she hit 31.3mph & 31.7mph. With the 4514 prop, I didn't quite break 35mph, but I did get closer - 33.7mph & 34.4mph (all runs still on 4S, with nothing else changed). Not sure if that's an average, above average, or below average improvement. Anyone who knows (stock vs 4514), can you let me know? Thinking the next thing I'll do is start adjusting the prop angle. Is down by 1mm a good start, or should I start with a greater, or lesser, adjustment?
Propping up to the CNC-4514 should give you a bit more speed on 4s but it might be too much prop on 6s.
I've seen several videos of guys getting good speed and stability running stock on 5s.
I would advise against trying to adjust the strut/prop angle as it's for all intents and purposes not adjustable on this boat unless you remove the stuffing tube and bend it by heating it up with a torch.
Thanks for the info on the prop/speed, as well as the heads-up on adjusting the strut. I thought I had read in someone's thread (can't remember if it was in the OSE, or RC Groups, forum) that they were starting to "play around" with adjusting the angle, which is why I thought it was adjustable....if it is, great, and if it isn't, that's ok, too. I'll take a look after my wife wakes up (during remodeling, the bed is my (temporary) "workshop"). After all, the SonicWake is my first boat, I'm a 'baby' in the FE world, and I'm still "crawling". The 'good' news is, I'm definitely learning...not only how to "handle" an FE, but also in understanding about various FE parts, such as the props.
Speaking of which - I'm running the 4514 for now (I never measured the stock prop, but I know it's smaller...probably 43mm dia.), and I'm wondering something. On 4S, would the SonicWake still handle well running a 4515, or (maybe even) a 4516? Although I still haven't installed them (yet), I do have the adjustable trim tabs from Boat Bitz. I'm assuming, if I were to go with a higher pitch, the adjustable trim tabs (by lowering them by maybe 1mm?) should help to stabilize the boat, right? I'd really appreciate some 'insight' on 1.4 vs 1.5 vs 1.6 pitch, at least in regards to the SonicWake (primarily on 4S, but also on 6S (see below)).
Moving up to the 6S questions, first, would a 42mm be the best starting point (on the SonicWake, obviously)? Or, would that be "overkill", meaning I should start with a 40mm? Second, on the pitch, should I stick with 1.4? Or, would it be 'safe' (ie. will the boat still be stable) to go with a 1.5? Remember, again, that I'll be installing the adjustable trim tabs. I'm assuming...and, probably, correctly so...that a 1.6 on 6S, in the SonicWake, would spell "virtually-guaranteed disaster", thus I won't inquire on that PROPosition.
Last question(s)...at least for this post...and, they're in regards to CNC vs balanced & sharpened props, and specific to the SonicWake. For more powerful boats (ie. racing), I'm going to make an uneducated assumption that balanced & sharpened props are, essentially, the "only way to go". However, for something such as the SonicWake, where do things stand? For 4S, I'll probably stick with CNC, as it's more about enjoying myself (and getting away from the wife for a couple/few hours). But, for 6S, are balanced & sharpened props truly a better way to go? Or, should I just stick with CNC props? While part of why I'm asking is due to cost (balanced & sharpened costs 2.5-3x the price of CNC), I'm also asking because I truly want to understand (not just "know", but "understand") the advantages & disadvantages of each...especially in comparison to each other.
When it comes time to get my second FE (I'm 95% it'll be a TFL Pursuit), I'm fairly certain I'll be going with balanced & sharpened...but, even with that boat, I'm uncertain, at least until I truly understand each type. It doesn't matter (much), yet, as that's a 'question' for another day, in a different thread (although, I am already researching the different Pursuit variants/options).
The stock prop is 44mm 1.6 pitch whereas the 4514 is very similar to the stock prop but 45mm with 2.52 pitch. For comparison I'm happy with a 42mm 1.3 pitch prop on 6s. The larger diameter higher pitch 4515 prop you are using is probably fine for 4s although I don't usually use CNC props so I'm not overly familiar with them other than they don't generally require much if anything in the way of sharpening and balancing. In theory a higher pitch prop will move the boat farther along than a lower pitch prop given the same rpm.
Most of my props are stainless steel or a beryllium alloy which can be very toxic to work on so I prefer to let a professional do the work of balancing and sharpening. Stainless steel props like Doctorprops are safe to work on but are very difficult to modify. They are generally stronger than the material CNC props are made of as well so they don't break or bend as eisily. I also prefer a prop with some tongue as opposed to one that has been detongued for the Sonicwake as it helps the boat get on plane faster with less initial cavitation.
At some point down the road if you start doing the prop work yourself you will come to understand how much time effort and knowledge it takes to do it properly and safely. IMHO a properly race prepped prop done by a pro is the only way to go and if done properly well worth the additional cost.
The TFL Pursuit would be an excellent choice for a next boat.
Hope this helps.
Thanks...and, yes, it helps...it REALLY helps. When I start going the balanced & sharpened route (be it in 3 days, or 3 months), I don't plan on doing the sharpening/balancing myself. I don't really have the time, or patience...plus, as a professional chauffeur, once work picks back up, I'll have even less 'available' time. As for the material of most CNC props, I get what you're saying. For 4S, I'm guessing 4515 should still be ok...maybe even 4516 (or 4416, if there's such a size)? On 4S, I'd like her a lil faster, but don't want to cause instability.
Regarding 6S, and SS vs beryllium alloys (such as the commonly-used beryllium copper, & beryllium-copper-titanium), how does strength & weight play into things? I can see "stronger" being a good thing, but guessing too much weight would be 'bad'. I wouldn't want something 'weak' (such as an aluminum CNC prop, especially if it's 6061...though, 7075 is stronger). I don't mind paying more for quality products...but, if quality & longevity aren't at least 3x greater than a 7075 CNC prop (based on the balanced & sharpened props costing 2.5-3x the price), I'm not entirely certain I can justify the cost for SonicWake props (again, for the Pursuit, definitely balanced & sharpened). In "best bang for the buck" terms, I'd say it's 60-40 preference to the 'best bang' side...but, the 'for the buck' side does still matter, just to a slightly lesser extent.
I've been looking over the balanced & sharpened props Steve carries - Octura, GrimRacer, & Prather. From what I can tell, the Prather props are all SS, the GrimRacer props appear to be a beryllium alloy of copper & titanium, and the Octura props are a beryllium alloy of unknown composition. In order of quality & strength, how would you place these three? Also, in order of weight (lowest to highest), how do these place? Obviously, I'm learning about diameter & pitch...but, at the same time, I'm having difficulty finding info (at least for these three) on quality, strength, weight, & expected longevity. Any info you, or anyone else, can provide on these points should help me in narrowing down my final choices.
I have ordered almost all of my sharpened and balanced props from Steve and they have all been excellent in terms of the quality of workmanship. They are not only balanced and sharpened but thinned. Then to top it off the blades are given a very fine texture to disrupt the flow of water over them. Octura and GrimRacer props all need a lot of work to be balanced and sharpened properly unless you order the ones that come balanced and sharpened. I would say Octura and Prather props are the most commonly used and the difference in weight between them is negligible. As far as I know GrimRacer props are mainly used on Aquacraft boats so not quite as common but good quality. If you don't hit anything they will all last a very very long time.
As far as I know the stainless steel props are the strongest but also the most difficult to modify. Doctorprops makes some of the best of this type on the market but shipping from the Ukraine takes several weeks.
If you're not racing competitively or trying to set a world speed record then CNC props are probably the most cost effective for you while you experiment with different setups.
Anyone try out on a CNC N642/3 propeller stainless steel from Doctors prop on there Pro Boat Sonicwake 36 ?
Love to hear your thoughts and concerns?
Too much prop for the Sonic Wake, I would go with a Octura M445 my boat screams with that prop on it
Yep way too much prop, you will burn up your equipment. A 440/3 from Doctor Props would work much better. My stock Sonic version 1 flies with it on 6s.
His SS props are a work of art. They are so sharp you have to be careful when installing them.
I have two props coming from Dr Props one replacement for the 642-3 which is going to be a two blade replacement and a prop for my Velles 29, both are unknown size and pitch to me at this time.
His props are amazing works of art they are about as perfect as you can get.
