Tailfins ? What Tailfins ??????????
Attachment 89432 Attachment 89433
Looks cool. Ul1 fins? How long you think they will stay on?
hand-made motor mount side plates, esc wire enclosed in rect. tubing :
Attachment 89434
solid cooling lines :
Attachment 89435
flex lube shield :
Attachment 89436
Speedmaster 60/90 dual pickup rudder (trimmed) and strut (converted from 1/4" to 3/16")
Attachment 89437
Setup : Neu 1521 1.5D
FCR 240A Esc
Dinogy 4S2P 5000mah 65/C/130C
Oct 447/3 to 450/3 easy 60mph
Want one built ?
Attachment 89438
Tony :smile:
rcboatbuild@hotmail.com
This one went "Down Under" [ to Australia, not the water surface:wink:] Terry's adding his own electronics
Attachment 97122 Attachment 97123
Tearing up Aloha-Land with a big TP-4082
Attachment 97124 Attachment 97125
This one's going to Chile :rockon2:
Attachment 97126 Attachment 97127 Attachment 97128
Attachment 97129
:thumbup1:Wonderful paint work/decoration.
Leo
FE30 ready to rig for P-Ltd Sport Hydro
Attachment 100507 Attachment 100506
FE30 going down under (to Australia) rigged for P-Sport Hydro with a Neu 1515 1Y
Attachment 100509 Attachment 100508
Awesome Sir! :thumbup1:
I had the opportunity to check out one of these hulls recently and was very impressed with the quality and finish. If I ever get the urge to build a hydro, this would be the one.
Thanks Joel. The FE30 derives its pedigree from the world-class line of big gas racers at Insane Boats - Jeff is a perfectionist and the lessons learned from his big boats filters down to the FE models. At the just-run FE Nationals, an FE30 took class First Places in both P-Ltd Sport Hydro AND P-Sport Hydro :thumbup1:
Just had to build this hotrod for myself :thumbup1:
Attachment 100577 Attachment 100578 Attachment 100579
First wet [ needed some rudder trim adjusting and a more serious prop ]
http://www.youtube.com/watch?v=2W2ihCljk8E
Tony, as usual, what a wonderful build! Looks awesome!:rockon2: Love that water outlet!:buttrock: Man, that boat handles like a Ferrari.
That hull looks fast and stable. I have seen a lot of very loose boats in this class. Half do not finish heat.
It's been said that, theoretically at least, ride-pad hulls don't do well in the rough. Attachment 100627
My other JC30 (current P-Ltd Mono NAMBA SAW record holder) out for a stroll in "mild" chop :unsure:
http://www.youtube.com/watch?v=qkiTfVT1LaE
Dave wants to race P-Ltd. with the option of changing motors to go P-Sport. Narrowed the T-180 to allow 4S2P batteries to fit beside the ESC. A .150 cable with teflon is installed with the option of pulling out the teflon and putting in a .187 cable I supplied trimmed to fit to "convert" to the P-Sport configuration with a bigger motor..
Attachment 104264
Motor mount, quickchange servo mount, solid waterline to clear servo mechanism, matching blue servo rod
Attachment 104265
ESC platform keeps ESC off bottom in case of slosh
Attachment 104267
Sharp blue hull. Dave special-ordered early-style cowl instead of later model turbine cowl.
Attachment 104268
Attachment 109212
To replace his last one that "got away", Dave had me build this gorgeous ballistic missle. A TP Power motor, T-120, and Dinogy 65C/130C 2S 5000's and considerable attention to detail including carbon/kevlar inlays this should be entirely capable of low-earth orbit :thumbup1:
Attachment 109207
Attachment 109210 Attachment 109209
Looks good Tony!
What size motor and kv?
Any inside pics? How much harder is it working on the smaller hulls?
Looks good tony
Motor : TP POWER 2935 6Y 2270KV
It seems that the small hulls take much longer ; this one took 3 weeks (but it was worth the extra time - I'm really proud of this build:thumbup1:)
Thanks Mike !
That looks sweet Tony.
You do great work Tony. I hope Jeff hasnt shipped my hull already so you can get mine ready for me.
Steve's crossing over to the "sparky" side. His MM V2 should be a great start.
TP Power 4050 3Y 2220KV ; T-180 ; 4S2P ; Spd hardware. I kept the layout super sanitary :thumbup1:
(Steve'll add his own graphics)
Attachment 111597 Attachment 111598
Attachment 111599 Attachment 111600
guess ur gonna have to build my mean machine for me
Steve's next entry into the "sparky" side : A P-Ltd Sport FE30. This green on black hull is so strikingly bright that Steve'll need sunglasses just to look at it (pictures don't do it justice) - I think there's Kryptonite in the gelcoat :biggrin:
Attachment 111842Attachment 111843
I configured the layout to allow a single 4S 5000 in front of the ESC or 2 X 2S 5000's in series
Attachment 111844
Graphics will be added soon
Attachment 111845
I like how you put flotation in every possible spot. Must come from experience. :bash:
