Nice work
The hatch seal will be Interesting :popcorn2:
I am over hatch tape ...
Nice work
Ah, you ended up going way forward as well. I was forced to as well. As you know. It looks good Ryan
So weird the differences in the gap between our two hulls. Yes, I'll be using the thin 1/16" neoprene tape along the horizontal lip. I need to do a little block sanding on the underside of the canopy so the front sits a little more flush. I'll probably then go around the entire perimeter of the canopy again to account for the thickness of the neoprene to keep it sexy! :bounce:
The water here is soft again, but its still too cold to compete with all of the other stuff I have going on the weekends. Soon though.
Had a few minutes in the shop tonight. The 6S packs are a tight fit to get in and out, but they fit, and are easy to adjust once in place. I installed the hatch seal and test fit the canopy to determine how much sanding I'll need to do. Measured the flex cables and cut them to length. Minor steps, but its all got to get done.
Attachment 164497 Attachment 164498 Attachment 164499 Attachment 164500 Attachment 164501
Still waiting on my water jackets to get back from the machine shop. Man, I need my own lathe. Over the weekend I cut the motor wires, installed the bullets, and heat shrinked everything. Still need to do the battery connectors. Today I finished the ESC mounting points. I normally try and mask my epoxy, but I laid these spots down freehand trying my best to keep them circular and even. I thickened up the epoxy with silica filler and graphite powder. I tacked in the T nuts last night with small dabs of JB Weld while they were attached to the bottom side of the ESC mount so that they'd set up in the proper location and level with the carbon mount. That worked out well, but it's just slow. ESC mount is done and will get attached once these dry. Waiting on a piece of carbon plate to come in to so I can make the top cover of the ESC mount that will hide as much of the wiring as possible. I also decided to stack my ESC's instead of side by side as it gave me more room to remove the battery sleds.
Attachment 164539
Looks good Ryan.
Sweet :thumbup:
Decided to re-work my ESC mount. I cut the standoffs down and made it two tiered. Slotted the carbon plate for velcro straps, and put it all back together. Start running all of my cooling lines and got a little too focused before I realized I still don't have my water jackets installed and those need to be tied in.
Attachment 164617 Attachment 164618
Also picked up a keyboard stand to make working on the boat a little easier at the water.
Attachment 164619
That part was challenging, this hull more so than most. I started with a fresh tube of silicone, rolled the bottom up, the grabbed the entire thing with a long set of needle nose pliers to 1) get the applicator tip up where it needed to go and 2) squeeze the tube while it was way up under the deck. The key is to mask off both the battery trays and hull walls first so you can be a little sloppy on the application side of the equation, then go back with a wet finger (I keep a small cup of water on the bench while doing this) and draw back on the entire length of the bead to smooth it out and wipe away all of the excess. Once all that's done, you pull the tape and you get nice, clean lines.
Thanks for the tip, I tacked it in tonight with what I can reach... been looking at getting a long syringe etc but will try this method...
I always use soap when smoothing with the finger tho... tip I picked up at work. (regular hand wash soap)
Okay, water jackets back from the machine shop and just wrapped them in carbon. Waiting for the epoxy to dry. Now I'm going to get a tweezers and pick out the splinters from my hand.
Attachment 164745
My receiver Life battery and power switch were delivered this week. I water proofed the switch as well as the ESC wire extension and Y harness. I need to start filling voids with foam and then find mounting positions for the electronics under the rear deck.
So much effort on this build,a real piece of art!
Congrats:olleyes:
Thanks. Lots of effort for sure, it's the results that I hope get a passing grade when it's done.
The water jackets are done!
Attachment 164753 Attachment 164754
Already passed,these kind of hulls deserve some extra care...made for eternity.
Almost there! Decided to change out the 4060 motors for 4050's. Had to use different O-rings to make the water jackets fit. The rear support ring also was no longer in the right position for the shorter motor can so I made a pair of shims from 2mm carbon plate to insert between the motors and the motor mounts. The shims allowed me to get a third mounting bolt installed. Originally, an alternate bolt patter on the motor mount had a hole too close to the 12 o'clock position to be able to re-drill it. Shifting the new motors back 2mm allowed me just enough room to capture the rear end bells in the support rings. I also decided the MBP collets were too close to the motor mounts, even after turning them down on a lathe, and swapped them out for an set of H&M collets. Got the OSE 8mm anti-spark connectors soldered onto the ESC's, but still need to get them installed on all of the new batteries. Just about ready to put power to the ESC's finally and program them. So close.
Attachment 165919
Attachment 165920
Attachment 165921
Attachment 165922
Attachment 165923
She floats! Last pass of the day. Did about 10 in total using two sets of packs.
https://youtu.be/k8QbdLvqSUU
Had a marathon solder session yesterday and put the OSE 8mm antispark connectors on all my 6S packs. Was up till about 1AM sorting out an ESC setup issue. I've never used these Fliers before and couldn't get them to boot up properly. Turns out, it was the anti-spark connector. I did not engage them fully and there wasn't enough voltage for the ESC to boot up fully. The voltage form the anti-spark circuit was enough to run the programmer, so it fooled me, and I never thought that the partial connection was giving me troubles.
Attachment 165987 Attachment 165988
Boat ran great for its first time out. I'm happy with the setup, pretty well aired out and stable, on a mild set of props. Still have a few leaks to sort out, but minor. Will try out some different props in two weeks when I get back in town.
Attachment 165989 Attachment 165990
Bolting on the jewelry for run #2. Big show is next weekend and there's not a lot of time left for testing.
Attachment 166230
Awesome build! Such a beautiful boat, I'm envious!
I recently experienced this exact issue and it had me fooled for a bit as well. I was setting up a 1/5 scale 4wd vehicle, and did not have one of the connectors engaged 100% so it was only making connection through the initial part of the connector. It was enough for me to set the parameters of the esc, but when I tried to test the throttle I popped the resistor inside the connector, burned it right off. Couldn't understand why from that point nothing would work. But I did not realize it right away what had happened. Took for me to unplug everything and when I plugged the packs back in, the connector I popped the resistor on cracked a high voltage spark upon connection. Then I realized what had happed, as that connector was not functioning as an anti-spark connector anymore, haha. So anyone using these connectors, something to pay attention to.
