Originally Posted by
RaceMechaniX
Hello Peter,
I have run a 2028 Castle in a similar size cat on both 8S and 10S. Both work well. 8S will require gas size props in the 65mm range. 10S will run 50-60mm props depending on blade count and pitch. I found low lift Octura X series 3 blades work nicely on Aeromarine cats. Very smooth and efficient with minimal bad handling behaviors. I think my preferred prop was a X457/3. If you have both 8S and 10S batteries, try with 8S first and the 457 prop you have to get a baseline and measure temps. Then try 10S.
