Stock UL-1 w/Seaking 180. What timing number for Best speed? Y or D?
I'm sure it's already on here somewhere - couldn't find it.
Thanks,
Thanks,
11.25
Stock esc is set to 10 degrees, I've assumed that to mean it's a Y wind and use a middle range timing, I run a Swordfish so I don't have that many timing options, low, medium or high.
A few more opinions.
https://forums.offshoreelectrics.com/...ghlight=timing
Stock esc is set to 10 degrees, I've assumed that to mean it's a Y wind and use a middle range timing... answer is yes to all three.
Heaving Earth has the right value, that's where I run my PB 1800Kv in IM-31(v1) - using SK-90A ESC. Got the info here... https://forums.offshoreelectrics.com/...proboat-1800kv
Hope that helps,
