Love my park after rain makes some fun puddles with trees and lots of water.
Upgraded my cheap venom boat with 2300kv drone motor, 10amp esc from a broken drone and 3s 1050mah battery got good 30 min run out of it.
https://youtu.be/Z3KI1TujH1g
Does it still self right? I've got a Venom that my kids have outgrown and Dad always needs a new project! Can you post a picture of the inside with the new parts installed?
This run it did not because I placed 3s in the front of the boat, this was my 1st run I just placed the battery above the motor inside the cabin and it fits perfectly. Will go in a few again and test if it will self right. Boat is 60 grams lighter than stock and way way faster. I have two one has a brushed motor upgrade faster than stock buy a few miles I'll run them against each other to see how much faster this one is. I like this boat more than any boat I own because how cheap, reliable, strong and agile it is. I was surprised that after 30 minute run motor and esc got berally warm with out any water cooling.
Because I didn't want to waste any money upgrading this I used spare parts from a drone the 2300kv motor fits perfectly in to original motor mount if it gets pushed back a little, entire nose is empty space now perfect for a flotation foam.
Pictures
i will put a timer and time exact time this battery lasts me.
i can't get it to self right wonder what i need to do... it does swim upside down from the prop pushing against the wind haha.
Ok I was able to make it self righting again by pacing battery closer to the hull wall offsetting the balance. It's a bit nose heavy but under full throttle it stays well above water.
https://youtu.be/u-hoOS_ETr0
Because the battery is up front the boat get off the line slow and fills up with water even if I have tape all around, need to find better solution to water proof it maybe the hatch tighter. When water fills up the boat no longer uprights.
Here is a video of a little race at the puddle brushed boat has upgraded brushed motor and is faster than stock.
https://youtu.be/tgbFbHU1fyg
Attachment 151397Attachment 151398Attachment 151399Attachment 151400
Found some smaller sized lipos will see how well it does on them much more room now whole front is empty.
I was able to fit everything back in original places think self righting should work perfectly now.
Attachment 151407
Put in 1800KV motor but bigger size and boat now flips over with out any issues.
Taking out these boats against my stock atomik barb wire lets see what happens in straight line.
ran it against my stock barb wire and off the line it puts good 20 feet on barb, because barb takes a while to get out of the water, full out throttle its about 5mph slower but its is extremely stable.
I have one of these Venom model UDI001 boats. Does the Emax 2390289 motor fit in the stock motor mount?
yes
I tried installing this exact motor and it does fit but you have to install the motor mount backwards (rotate it 180 degrees). A little grinding will be necessary as well because the Emax motor has a 28mm diameter as apposed to the stock 370's 25mm diameter. The problem is the motor has a giant diameter threaded shaft that's designed for a model airplane propeller and prop nut. A custom coupler is required to be able to connect the Emax motor to the stock prop shaft. It appears silencepr opted not to use a coupler and somehow JB welded the motor shaft to the prop shaft. I'm sorry but it looks kind of hack. It obviously seams to work, however, so I commend his efforts. I have severe OCD so I couldn't live with marrying the motor shaft to the prop shaft with glue. I think silencepr is on the right track with using an drone motor in this boat, but one with a more conventional (RC car and boat friendly) motor shaft is better choice. I continue to use the stock motor, which is perfect for running the boat in swimming pools. Replacing the ESC with one that can handle 3S and using a small 3S battery pack is a better speed option than going brushless in my opinion.
