O ok , when they eventually do it I can download it to the ESC.:beerchug:
Did a GPS run with some CNC props lol on 7S and got 88.5 mph.
Next run will be 12S And with some decent props that I got from Chris, should be good :roflol:
Go man go!! Glad to hear good things on the ZTW.
Lol will see when used on 12S :beerchug:
https://youtu.be/4-Oo_xh4CAE 7S run.
Ahh, saltwater. I have not contended with that as of yet. Keep her clean. Thought I heard rumour of Boats being faster on saltwater. Difference in hard and soft water too. Just rolled off the top of my head this morning, haha
I suppose it would be, thicker soup so to speak :laugh:
What's the word on that 1 or 2 Mile an hour difference?
Less prop slip on salt water & hull is more buoyant as well, cant say in terms actual speed difference as i have never checked speed with a gps on salt v fresh water. I run mainly on salt water, when we used to take our same boats & props & ran on fresh water the boats always appeared to be revving higher but also looked to be slightly slower.
ZTW has the worst customer support. I went to there website to update my ZTW Geico programmer and it locked up the programmer. Then I contacted them to see if they could help me and got the response to contact the place I bought the programme from. I told them it worked fine untill I update the firmware and they did not respond for a few days. I contacted them again and gave me a big FO.... I have 3 ESCs and the 2 programmers I typed to update no longer work. I would go with anybody else but them. Never had customer support like that. Rude the whole time.
Any new runs with the ZTW 300a? Do they have reverse? I saw it has a brake function...
Update run 12s
https://youtu.be/k0IHCXAY8B0
Let me know, what you think happened to the shaft :confused1:
Well I’m not sure but it sounded like a prop came out of the water mid run. Unless that was the prop coming off, but the rest of the run did not sound like or exhibit a sign of only one prop working. They usually take a dive right or left when you lose a prop (or worse). Perhaps it let go when you let off?
So what KV or more importantly what rpm do you figure you are running. I’m just curious as I also have a set of AB 447’s on my HPR 115. I haven’t given her the coals yet.
Lol Thanks.
After checking it's the fastest rc boat period in Australia to my surprise lol , not sure yet if to up the voltage or props still thinking about it.
ZTW ESCs working flawlessly so far , knock on wood .:Praying:
https://youtu.be/4xXGorz_wGk
There is no data logging with the ZTW 300 is there ?
Which ESC would you think is the strongest the Swordfish 300 or the ZTW 300?
Thanks for the reply I am running a F-41 Stryker Cat with a SSS 56-104 1000Kv motor on 8S2P oval racing I was wondering if the ZTW 300 would be strong enough. Right now I am finding out what the motor will handle in prop. I have a MGM 400-63-3 with a big cap bank But it is borrowed from another boat and I do ot want to have to take it out Saturday boat that night and install for Sunday boat.
Attachment 166275Attachment 166276
