If I'm running two lipo packs too a swordfish 240 esc will I be ok soldering a Y setup on the esc.. (like a stock traxxas erevo esc comes set up).
Why do you need a "Y"? if you are connecting the batteries in series, just hook up the batteries' + to- and the other + and - goes to the ESC.Attachment 125309
if it is parallel then you need a parallel adapter . Attachment 125310
I am assuming you are using bullet connecters.
***edit*** this only applies is your doing them in series. You never stated one way or the other.
Here's how I did mine...
http://i218.photobucket.com/albums/c...207_133651.jpg
This a seaking 180. I did the wires the same. Run the red one way, black the other and then a jumper between the positive left on one battery to the negative on the other battery. Essentially makes a loop through them. You can see it better on the swordfish 240. That black wire going under it is just a jumper. Hope this helps.
http://i218.photobucket.com/albums/c...119_220701.jpg
Awesome, thanks guys!
You still didn't mention in Series or Parallel ? Very important :thumbup1:
It would be two packs in series with 6.5 castle bullet connectors
