Worked like a charm Sam!Attachment 161472
Not quite yet. I have been traveling for work so i decided to let some guys at the local hoppyshop do some of the wiring work while I'm gone. Shortening the wires between the motor and ESC and all connectors will be Castle 6.5mm bullets...including all the batteries. Should be ready when i get back in a week for me to switch out the servo, install the cooling lines, add an after-market turn fin and then, of course, the strut height/pitch adjustment which, frankly, seems to be the most complex of anything to me.
Sam,
Fortunately, with all the time I had waiting for the boat, I did manage to build a nice custom carrying case for it as well as a retrieval rig which i am hoping will be large and powerful enough...Attachment 161473Attachment 161474Attachment 161475
Interesting post. This is the exact situation I want to avoid because I've been close with one of my cars and realized I was spending more time tinkering and upgrading than I was actually just having fun driving it around. Of course, I'm not looking to hit 70+mph speeds but rather be able to run it around at 60+ with good control and at least a few minutes of battery life. I do salute the work and experimentation you've done however as, at least speaking for myself, you've allowed me to avoid a great deal of trial and effort and I've learned a ton from reading these posts. Much appreciated!
I would say the dual water is the problem, They extend to far down and what I would do is cut some off the pickup pipes off and bend forward close to 90 degrees and leave the pipes inline. The current long pipes cause drag. BTW, nice BOAT.
Sounds like a bit of a ‘Ah hah’ moment. We all have them. Can’t see the forest thru the trees, blah blah.
I have limited hydro experience but one thing I have had success with is pulling water off the sponson bottoms. IF you are having cooling issues. This should be less for you as the water cools now. I love fall/spring running for this reason.
Also if you are going back to stock on the rudder you can take a debuting ball(Dremal) and just teardrop the inlet of the rudder. This is usually plenty.
Do you know how thick that piece of wood is? Meaning, my local hobby shop has tons of variable thickness wood sheets and it would be great to be able to just go but the exact pieces I need. Sorry, may be a few questions coming in- I'm now in the heat of setting my boat up :-)
