Attachment 166219Attachment 166220Attachment 166221Attachment 166222 Moving right along. Servo mount, carbon posts with nylon inserts. Just finished the dress up washers.
Attachment 166223Attachment 166224Attachment 166225Attachment 166226Attachment 166227 Just finished the servo mount , carbon posts with nylon inserts. Spun up some dress washers too. Couldn't have done it without the help of Taylor, "Big Mister".
The orange epoxy is a nice touch. Did you make your own brass barbs for the water pick-ups? If so, how did you make the cone pieces? I ended up just soldering on a small section of brass tube one size larger to give the hose something to bite on.
No i didn't, but that's not a bad idea. Nor is the way you're doing them. That works too. I think i could cut my own tho, using the rotary table and like a 60° dremel burr, or something of that nature. I had purchased these from OSE. Quick and dirty! Thanks for the compliment. I dumped a lil createx in the g flex. Makes it a little stringy and a tad thicker too especially with micro fibers in it.
I'd love to share some of my recent progress, but for some reason every time i upload it says "upload failed". Any suggestions?
Alright! I'm back to posting pictures. A little more of my progress, and some more handy work on the mill.
Attachment 166508Attachment 166509Attachment 166510I got the linkage close. A little more tweaking and I'll have it. What a long drawn out process fabricating the servo horn, clevis, and pins out of stainless steel socket heads.
Your machine work is gorgeous. What machine tools are you using? I'd love to have a small lathe/mill someday.
Cool KBB style small cat.
Attachment 166690Attachment 166691Attachment 166692A little more progress. Esc mount painted and ready for clear coat. I quick look at half the power plant. We're sneaking up on it. Won't be long now.
Attachment 166739Attachment 166740Attachment 166739Attachment 166741 Moving right along. Carbon posts for esc mount are in. Got the mount all cleared up. The carbon really comes to life under some high solids clear.
Attachment 166746Attachment 166747Attachment 166748 Power plants hooked up!
Attachment 166798 The race gas arrived today straight from Singapore!
Nice. I always got pretty quick shipping direct from Revo.
Attachment 166867Attachment 166868Attachment 166869 Got all the soldering done. That was a lot of work. Gonna start routing wires and start plumbing.
Attachment 166956 I'm not the only one dreaming of finishing this thing. Sometimes he even helps! :banana:
Hay man if you don?t mind where did you get the outdrive made and your rudder
I machined the strut standoffs, rudder standoff, and rudder on my benchtop mill. There should be pictures of all this being made except the rudder, i forgot to snap some pictures of it. Struts are OSE 3/16" cut down and turned the bevel using my rotary table. Should be some pictures of this as well.
