5 Attachment(s)
The Black Pearl P Sport Hydro 2017
Hi everyone. I made some changes to the boat this year, so I figured I’d start a new thread for the latest build. I’m still maintaining the original goal of ‘stability’ and it still has the integrated FE motor mount.
V6.2 Changes:
>The overall height has been reduced about 8mm. It’s a bit sleeker looking now and can still package (2) 5000mah batts.
>The ride pad width has increased by 5mm per side. I’m hoping this will ‘hold up’ the boat more with the heavier, higher capacity batts. In addition, if anyone wants to build up the sponsons to run loose (many have done this), you could follow the outer angle and still have decent ride pad width.
>Added support under the deck between the last frame pc and the tips. I noticed there was some flex in this area on the last version.
>The tapered air bleeds will remain unchanged.
Some photos of the previous version and a link to the previous build and vids below....
https://forums.offshoreelectrics.com/...ort-Hydro-2015!
